The time (T) required to drive a fixed distance varies inversely as the speed (r). If it takes 5 hours at 80km/h to drive a fixed distance,how long would it take to drive the fixed distance at 50km/h?
the intensity of illumination of light source varies inversely as the
square of the distance between the source and the piont at which the
measurement is taken. if =20 lumens when d=5 meters, find i when d=2
meters
How long it takes to drive any distance depends on your average speed. Whatever is your average speed, divide that into the distance you have to travel. For instance, if your speed is 100 kilometers per hour and you need to go 400 kilometers, it will take you (400 km/100 kmph=) four hours. Always be sure to use the same units of measurement, English or metric, in your arithmetic.
The cosine of 52 degrees is about .6157 . The inverse cosine of .6157 is 52 degrees.
52 degrees is a measure of an angle. .6157 is a distance. The cosine of an angle results in a distance, while the inverse cosine of a distance results in an angle. There is no such thing as the inverse cosine of an angle, just as there is no such thing as the cosine of a distance. It's like asking "How heavy is one hour?"
If you're asking how to calculate a cosine or inverse cosine on your calculator, please specify the make and model of the calculator.
I have the same problem for two weeks, three times I ordered dragged checked my fuel pump replaced sensor passed over gas pump and the fuel filter fuel filter checked syringes All right already and high costs
Car turns off the light in the car there's watches on 'CHECK' 'but it seems gust mal engine fuel pressure monitoring -p1181
I am at a loss and 10 mechanics only take money from me and untreated malfunction
Please note I replaced all 4 months ago all VAT radiator engine
Assume X is the intensity of the radition at 0 meters.
Then 62.5 milliroentgens/hr = 1/(3^2) * X
Solve for X. X = 9 * 62.5 milliroentgens = 562.5 milliroentgens/hr
Now solve for the radiation at 2.5 meters.
R = 1/(2.5^2) * 562.5 milliroentgens = 562.5/6.25 = 90 milliroentgens/hr
