To reset the password.
Shut off the power supply, or unplug it.
Press the start button.
Remove the battery for two minutes.
Replace battery
Re-energize power supply.boot the computer to the BIOS.
1. Enter wrong pattern 5 times and wait for 30 seconds.
2. Select "Forgot pattern" and enter your email account username and password.
3. Make sure you use the same account that was used to activate the device and double check the password by logging in to that email account in a browser.
4. If you don't have access to the original email account, you will need to do a hard reset and loose your settings and apps on the devcice. The data on the memory card will not be wiped though.
Note: if you can't remember your email password, you will have to visit the email service support page to get it reset.
also, see here... http://www.androidtablets.net/forum/android-tablet-usage-tips-tricks/6280-forgot-your-unlock-pattern.html
or here... http://mytabletguru.com/forgot-password-pattern-unlock-of-android-tablet/
hi if you forget your phone password then try default codes like 000 or 1234 to reset it .if it didnt help you to reset it then visit unlocking4free.com here they generate master reset codes for some nokia and alcatel mobile models at free of cost.
If you forgot your password, reset your phone to factory settings. Look under phone settings and you will find it there. You may want to refer to your phone's manual.
Also, you may want to post your phone model so we can assist your further.
sir try this key [00000 or 12345] [0000 or 1234] if this key is invalid then connect to the pc and copy the datas to the pc then you formet the memory card.it will not ask the default passward.............
plug it into your computer and through itunes on your original computer you will be able to reset it. If it is not the original computer that you are using you will be able to reset it but will probably lose the information on it.
Ruben,
If you really can't recall the password that you have set on the router, then the only wait to get around it is to reset the router, by pressing the reset button on the back of the router for 10 sec.
by the way have you already tried admin for password and no username?
