sonata relay - sunroof Logo
r
rizwan ali shah Posted on Jul 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SUNROOF SWITCH SUNROOF SLIDE IS NOT WORKING
RJ motortech auto repair
Level 2:
Habit-Forming:
New Friend:
  • Expert 75 Answers
  • Posted on Jul 03, 2014
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
75
Questions
0
Helped
20934
Points
172
Sometimes need to be reset,if its not.check the power to the motor,if the power get to the motor,its the motor problem ,otherwise it might be the cable seize up..it needs to dia
2005 saturan view sunroof wiring
What about saturn vue sunroof wiring ? U want a wiring diagram ? Not working at all ?
The power sunroof system consists of the following components:
• Sunroof module
• Sunroof motor with limit switch
• Sunroof switch
• Sunroof glass, tilt/slide type, with glass sliding between roof and headliner
• Sunshade
• Rail and track assembly upon which the sunroof glass rides
• Sunroof system fuse: sunroof 20 A fuse
• Ground G401
You can find free wiring diagrams here http://www.bbbind.com/tsb-wiring-diagrams-database/
tip
2002 Jaguar XType Sun-roof one-touch operations reset
I had this issue and found the solution around, worth sharing and it takes 30 seconds: <br /> <span> <li>Press the sunroof switch forward to move the sliding roof panel into the tilted position.</li> <li>Release the sunroof switch.</li> <li>Press and hold the sunroof switch forward until the sliding roof panel moves slightly. This may take 30 seconds or more.</li> <li>Release the sunroof switch.</li> <li>Immediately press and hold the sunroof switch in the forward position. The sliding roof panel will move down and rearward to the open position, and then forward into the closed position. Do not release the sunroof switch until the sliding roof panel has stopped completely.</i></li> <li>Your sunroof panel should now be aligned.</li></span>
on Jul 11, 2011 • 2002 Jaguar X-Type
2helpful
2answers
Nissan rogue sunroof wont slide open. It will tilt up but not slide
1. Place the ignition switch in the ON position.
2. Push and hold the sunroof switch toward 2 . Once the sunroof has reached the full tilt position, release the switch. Push and hold the switch toward the 2 position again. After a delay of four seconds, the sunroof will make a small movement and backup.
3. Release the switch.
4. Within 5 seconds of releasing the switch, push and continuously hold the switch toward 2 . The sunroof will move from the tilt position to the open position and back to the close position.
WHERE CAN I DOWNLOAD A 2004 CADILLAC CTS REPAIR MANUEL?
Here's a description the sun roof
Power Sunroof System Components
• Sunroof module
• Sunroof switch
• Sunroof motor, with 2 hall effect sensors and limit switch
• Sunroof window
• Sunroof sunshade panel
• Power supply for the sunroof module: RAP 25 A
• Ground G402
Override
The override function is used when needing to force a closing of the sunroof window. To override the system:
Turn ignition to ON.
Rotate the sunroof switch to the close position.
Press upward.
The sunroof switch data 6 circuit, or override circuit, will become grounded at the sunroof module. As long as the sunroof module sees this input, it will continue to slide the sunroof window to close, regardless of the other sunroof switch data circuits inputs.
2001 cadillac deville sunroof open and want close
Check the RAP fuse in the rear fuse box , this fuse powers the sunroof control module ! Fuse Block - Rear , Left rear of the passenger compartment, under the rear seat .
The sunroof module contains the logic for the opening and the closing of the sunroof. The sunroof motor assembly contains the reversible DC drive motor, the gear train, and the limit switch.
The sunroof module determines the sunroof motor direction based on inputs received from the overhead console sunroof switches. When the ignition switch is in the ON position or when retained accessory power (RAP) is active, voltage is applied to the sunroof module via the RAP relay. For a description and operation of the RAP system, refer to Retained Accessory Power (RAP) Description and Operation in Retained Accessory Power. The sunroof module controls the sunroof motor direction by changing the polarity of the applied voltage. The sunroof module remembers the sunroof position whenever the ignition switch is turned to the OFF position. The limit switch is used as an input to the sunroof module to indicate that the glass is fully closed, or in the comfort stop positions. The limit switch is grounded when the sunroof glass is in the fully closed or comfort stop positions, otherwise it is open.
The SLIDE CLOSE mode is initiated by moving and holding the sunroof slide switch (ROOF) forward. This applies a ground provided from the sunroof limit switch low reference circuit to the sunroof switch close vent signal input of the sunroof module. The sunroof module controls voltage to the control circuits of the sunroof motor. The sunroof motor will run until the limit switch contacts are closed. The closing of the limit switch will apply the sunroof limit switch low reference circuit to the sunroof limit switch soft stop signal circuit to the sunroof module, indicating the flush closed position has been reached. As the sunroof is approaching the close position the sunroof glass will force the wind deflector downward.
You need to have a factory scan tool hooked up an have it checked for DTC'S in the sunroof control module ! a code reader will not do this , a code reader will only check the engine codes for OBD 2 .
Important: The following must be completed before using the symptom tables.
  1. Perform Diagnostic System Check - Power Sunroof in order to verify that all of the following are true:
  2. ?€¢
    No DTCs are set.
    The control modules can communicate via the serial data link.
  3. Review the system operation in order to familiarize yourself with the system functions. Refer to Sunroof Description and Operation
your better off taking to the dealer !
2006 CHRYSLER PACIFICA SUNROOF PROBLEMS CLOSING SUNROOF BUT THE FUSE APPEARS FINE. HOW CAN I GET IT TO CLOSE?
spray crc55 or wd40 into the slides and work the switch until it begins to work, once functioning repeat with silicone spray
3answers
Sunroof won't close
see the diagram attached and fix it. God bless youaa64eb51-7e11-4e93-a5bc-68a552df4913.jpg3d325aa6-02b4-4a16-b487-b8a581cd3d55.jpg
Need to replace sunroof..
you need to replace glass or is it leaking if leaking then you have to remove upper seat belt covers pop off remove bolt 14mm and the trims on upper pillars pry off carefully held in by clips remove covers on interior light at front where sunroof switches are there are screws by bulbs disconnect connector remove center light cover and screws disconnect connector with clean hands remove rbber trim around sunroof opening and plastic cover on each side of sunroof glass held on with plastic screw clips then remove four 10mm nuts lift sunroof glass out of car remove cover and screws from rearview mirror all plastic trims around headliner move pass seat forward most and flip back rest all way down roll pass window fully down then slide headliner out of car now you can remove electrical connectors and remove water flow hoses from sunroof unit remove 8 12mm nuts holding frame to roof remove through door you will see the track sunroof slides on remove nuts along problem is silicone between track and frame is deteriorated lift track clean replace silicone reattach frame to roof dont put trims or liner in till test connect switches and glass to frame make sure sunroof works and closes fully then go through car wash to see if leak is fixed
21helpful
3answers
BMW X 3 Panoramic sun roof initialization.
title says X5, but description says X3. i'll explain for an X5, but X3 with the pano should be the same. and i'll explain function of the roof, not reprogramming.
button is located on the panel at the top near the front & center windshield. its the switch on the far left on this panel. its a switch that not only toggles, but also slides forward & back.
with your finger in front of the button, slide it back & release. this will make the cover slide back and store revealing the sun roof. you know have 2 options (tilt the sunroof up or open the roof completely).
to tilt it up, press up on the rear of the button and release. the rear of both roofs will pop up. to close, push up and release the front of the button or slide the switch forward.
to slide it open completely, repeat what you did to open the protective cover (slide the switch from front to back). the roof will open completely and stow out of the way. to close, slide the switch forward and release. pano roof will now close.
to close the cover, slide the switch forward again.
neat trick: if you want to tilt the sunroof open without opening the protective cover, press up on the rear of the button (when the cover is closed) and release. the cover will separate in the middle exposing about a 2-3 inch mesh, then tilts the sunroof open. to close, push the button forward again.
also, if you are above a certain speed (can't remember what it is off hand) with the sunroof open or tilted, it will close automatically, then perform the neat trick on its own to keep air coming in.
one last trick: if you want to open the windows and sunroof from outside, press & hold the unlock button (forward button on the key) and you will see the windows go down, then the roof will open to vent. releasing the button will stop the motion of the windows & roof.
hope this answered what you were asking.
Jan 27, 2009 • 2005 BMW X5
Top Hyundai Vehicle Parts & Accessories Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Vehicle Part and Accessory Expert? Answer questions, earn points and help others
