After washing in cold water there are purple stains all over the shorts, we think it is from the label inside the shorts, we cannot remove them, please help!
spotremoval.coit.com/how-to-get-blood-out-of-carpet
How do you remove blood stains?Follow These StepsWet the stain with cold water. If the stain is fresh and still wet, soak fabric in cold water immediately.Rub with soap. Rub the stain well with a bar of soap, lathering gently. ...Re-soak the stain with a pre-treatment stain remover. ...Dab on diluted ammonia. ...Launder fabric.How to Clean Blood Stains Video and Steps - Real Simplehttps://www.realsimple.com/home-organizing/cleaning/cleaning.../remove-blood-stainsSearch for: How do you remove blood stains?
or try this link. How to get blood out of carpet Google Search
Immediately apply water on stain and try to absorb oil from the cloth using tissue paper. Once you are home, take a lemon, squeeze the juice on the stain, keep it aside for 30-45 minutes. Next apply detergent powder on the stain and rub gently, wash with water. The stain will get faded. now soak the cloth in soap and water for 1 hour and wash gently. After one or two wash the stain will go completely.
Have you ever experienced washing machine stains, where your machine is the culprit for ... Just never put clothes in when doing this as it will discolor them. ... I get largeyellow spots on my Battenberg linens after washing, or maybe they ...
The Clorox CompanyFeb 4, 2010 - I do my laundry at a neighborhood laundry that has. ... into the machinefor the wash cycle but still get the yellow spots. ... Since you diluted it in a gallon of water, the yellow spots/splotches should not be from the liquid bleach. ... Rinse and air-dry to see if it has any effect before doing a large number of items ...
Blood stains are considered to be organic stains because they contain
proteins. Protein is the building block for nearly every living thing on
the planet, but it's also what makes removing a blood stain difficult.
Proteins react chemically and bind to one another; typically, you can't
remove blood stains completely using traditional stain lifting methods.
To remove blood stains from clothing, avoid exposing the garment to heat
or hot water. Opt for using a natural enzyme to lift the stain instead
of using bleach, or other chemical stain lifters.
To ensure the best results, you should treat the stain immediately. Begin by rinsing the stained area under cold water. If the stain is still there, try rubbing a mixture of liquid laundry detergent and water into the stain. Allow this to sit for about 5 minutes before washing.
First look at the cleaning label for cleaning instructions. I am assuming this is cloth and toothpaste is generally a non-greasy type stain. I have listed some mixtures that may work
Use cold water for non-grease based stains. Mix 2 teaspoons of mild detergent with 1/2 cup cool water, whip in froth and apply. Apply with care and test an area.
then add some soda water. You can just start with the soda water. It won't hurt and I think it is quicker.
If these don't work, call a dry cleaner and ask for advice. Toothpaste is a "soap" so it might not be too difficult. Easy for me to say...right...
Finally, I HIGHLY recommend that you obtain book I use ALL the time. "Haley's cleaning hints." or some other book of this type. It has been a life saver for me over the years-
Example: hairspray can help remove lipstick stains..whoda thunk it!
Yes, any machine should work with just a cold water supply. The internal heating element will bring water up to the required temperature.
Most machines sold today have only cold water fill, as that is better for removing stains - putting hot water onto a stain will set it rather than remove it.
Sounds like rust stains, coming off the inside of the drum, you will need to find the source of the rust. Maybe a loose screw or something metal stuck inside the drum. Carefully run your hand around the inside of the drum and check for rough jagged edges to identify anything that should not be in there.
