I had a similar problem with the bike in my avatar. It'd be running along, then all electrical would die (engine, lights, etc). Turn key off, then back on, and all would be good until next time.
More likely to be your ignition coils. They heat up and expand this can cause an open circuit which will close up again when it has cooled down. Although, a bad charging system may cause this problem. Check the battery voltage with engine switched off ( approx 12 volts) and with the engine running (approx 14 volts) If you are getting 14 volts then your battery is dead, if you aren't, then your charging system has a fault.
