Wont fill w/water
SOURCE: Washing machine Kenmore 3.2 cu ft Super capacity plus top loader
fabi, if Im reading you right the machine fills with water and just sits there. Can you hear the motor running when it should be agitating? If so you might have a broken coupler. If the machine is quiet and just sits there, it could be the pressure switch. The first picture shows the pressure switch with the rubber hose and purple wire going to it (far left). There is no model number posted but this is a top loading Kenmore, should be close. Take the rubber tubing off the switch and blow into the switch with another piece of tubing. Does it start agitating? If so, there's your problem. If you do hear the motor running and it's not agitating it may be the motor coupler. If you need more assist...email me at [email protected] Catriver..post back.
SOURCE: Whirlpool Kenmore 2.1 cu. ft. Compact Portable Top Load Washer
did u try leaving the lid pushed down? I just had the same problem and had to push down on the lid in oirder to get it to work and leave it pushed down during the entire wash, it was quite a pain
SOURCE: Kenmore 2.1 cu. ft. Portable Washer - won't drain
Probably something caught inthe pump. Will have to remove pump and take obstruction out. Only other thing I can think of is the pump ran tight and would have to be replaced
SOURCE: Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
SOURCE: Compact Kenmore top loadwasher does not spin
Clutch is failed. replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
