Reset button
on the ergonomic handle design the vibration will sometimes cause one of the switch leads to come loose. Remove the handle tube. Lay the handle tube flat on a bench or table and remove all the handle screws. Work handle haves apart and you will be able to see if the switch leads are loose. If not, the wires inside the power plug may have become separated by somebody yanking on the cord, rather than pulling the plug. With a meter or test light, you can check continuity between the plug and handle wiring. The only thing left is the motor, but let your local repair guy do this, because it can be a bear to get out and re-installed.
