Fluke Multifunction Electrical Tester
A wide range of multifunction electrical testers from manufacturers like Fluke and Robin Ampobe. Order your multifunction test kit today!
Know more here:
http://vfmmeters.co.uk/multi-function-electrical-testers-10-c.asp
There is no reliable test for electric water heater thermostats
Replace thermostats
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: My electric reliance water heater is making a constant noise
it might be hard water in the heater. the hard water flakes and when your water heater turns on it creates some movement in those hard water flakes and makes a popping and hissing noise then when it comes to temperature it should stop. the temperature and pressure relief valve shouldn't make this noise. but if you stick your finger in the pipe and it is wet then you might have problems some where else. let me know if it is
SOURCE: Our 606 reliance electric hot water heater has the
We will just assume that "a" is the lowest temperature
to correspond to 120 degrees, while "c" for 160 degrees.
So try setting it at "a" and feel the hot water that flow.
Or it could be the other way. Just feel the hot water that
flow. It will be done in a few minutes. I hope this will help
you.
SOURCE: Water Too Hot
needs new thermostat(s) If the whole tank is heating( next time it trips, before using any hot water check the lower tank thru the lower element access(breaker off) If the lower tank is hot-you need a new lower thermostat. if just the upper part of the tank is heating -you need an upper thermostat.
SOURCE: Pilot won't stay lit in Reliance 606 gas water heater
The Reliance 606 has an enclosed thermal couple. Before you try taking that assembly apart take a wire brush to the bottom opening directly under the burner. There is a metal filter on the very bottom of the water heater. It could be that the filter has gotten filled with dust or animal hair. It took a serviceman 2 days to figure this out for me. The water heater has to have good airflow through that filter to work well.
SOURCE: how to change a thermostat on reliance 606 hot
I wrote a page for changing water heater thermostat.
The photos take you through step-by-step
I recommend replacing both upper and lower thermostats so it eliminates thermostats as possible cause if water heater keeps overheating.
The Reliance 606 manual shows your water heater uses generic upper and lower thermostats from hardware store.
http://www.reliancewaterheaters.com/lit/om/manuals/185761-000.pdf
Likely the thermostat will solve the problem:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
