Question about Evenflo Jenny Lind Crib
I'm trying to put the ends on the box spring and their r two holes one has a wooden peg that fits into hole the other doesn't so is a screw suppose to go in r a piece of wood
I'm trying to put end of crib onto the box spring metal so how do u secure the pieces together
4 Suggested Answers
SOURCE:
SOURCE: I don't understand putting it together.
My solution may be a little late but I just had the same problem today. I wanted to share this information with you! Good Luck
Go to daxstores.com at this point you can opt to live chat to a service rep. Then I typed her my situation and gave her my model number. She popped up instructions for me almost immediately! I printed them out and am putting the crib together now! Hope this might help others :)
Marty
Posted on Mar 31, 2009
  • 5 Answers
SOURCE: how do I attached mattress spring to crib base
The above picture is how our Jardine Enterprises crib attaches the mattress support to the frame. I am thinking you need the bolts to make your crib work. And that might be a chore unless you are very handy with hardware. Also, being a new parent ourselves, I would recommend against anything but the safest crib for your child. Call the original owner--see if they can find the bolts/hardware, if not get a complete unit if you can afford it, it may cost more in the short run, but may save a serious injury or worse. Also, if you go the used route see if it has been recalled, you can start here:
http://www.thenewparentsguide.com/choosing-a-baby-crib.htm
Posted on Jun 05, 2009
blueextc3221
  • 15935 Answers
SOURCE: we tried putting crib together but it seems to put
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 17, 2010
Open perplexus ball
The ball is divided into two hemispheres which are joined with the blue plastic pieces (at least on our Epic) at the equator. One half of the blue equator piece has pegs that are glued into holes (like a dado I suppose). We had the same issue with the blue tube coming apart. I used a dinner knife with a blade thin enough to fit into the joint between the blue equator trim pieces, but sturdy enough to allow me to torque it a bit. I slowly worked around the ball (several times) seperating the blue equator pieces. Only one of the pegs came out of its hole; all of the rest broke at the base, so while I can refit the equator pieces back together, I will need glue to finish the job. As well as being glued at the pegs (which were located at the points were the maze assembly meets the equator of the globe), there was periodically some glue along the length of the two blue equator pieces. Once apart, the clear hemispheres easily come apart and the maze assembly is easily removed. These did not appear to be glued anywhere. Fixing the tube was a snap, as was re-assembling everything; as I said, I just need to re-glue the blue trim pieces back together to hold the entire assembly together.
Be aware that in order to open the unit, most of the pegs broke, so proceed at your own risk. By prying along the perimeter of the equator joint gently, the toy can still be reassembled and glued/repaired, so don't rush!
Nov 26, 2011 | Explorer Appliances Perplexus Maze Game
How do I replace the pull start?
Remove the four screws securing the starter houseing, with the starter removed, pull the cord out, tuck the cord into the cut a way in the side of the pulley and allow the cord to wind in slowley to let the tention off the spring, make sure all the tention has gone, now remove the centre screw, take away the pulley centre and the round spring from behind, note the hole in the pulley and the centre hub for the spring location, now carefully remove the pulley, be aware there is a large spring behind, remove the knot in the end and remove the starter handle, fit the cord back into the new pulley, refit the pulley into the cover making sure to locate into the spring behind, thread the cord back through the cover and reconnect the handle, knot the cord, re fit the round spring back into the locating hole in the pulley, re fit the pulley hub making sure the spring fits into the hole in the hub, re fit the securing screw, now put the cord back into the cut a way in the side of the pulley, wind up the spring, allow it to pull the cord back into the starter, only wind it enough to pull the cord fully back into the cover, re fit the starter.
May 01, 2011 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
Wooden train set track, pegs missing! Where would I be able to buy some spares, please? It's for Brio compatible track, but not sure who it's made by... Help! This is driving us crazy!
If it helps I've repaired similar track by plugging the hole where the peg went with a small rawlplug trimmed to fit then screwed in a metal eye fixture (1 cm diameter) of the type used in hook and eye fastenings or to hold up net curtain wires. The eye fits the adjacent hole and the eye can be screwed in and out or tilted to fit.
Roger Dyson
Mar 13, 2011 | Toys
Replace rear tail light on ford focus wagon 2000
http://wiki.answers.com/Q/How_do_you_replace_the_tail_light_assembly_on_a_2000_Ford_Focus_SE_Station_Wagon
abar_a.gif?v=77611 Remove two screws and rotate to the side
To remove the rear light assembly for access to turn signals and brake lights:
1) Open the trunk to expose two screws.
2) Remove these two screws.
3) There are two brackets still holding the housing onto the car. Do NOT pull up and do NOT pull up on the housing; you will break the plastic pegs on the lamp housing.
4) Referring to the driver side lamp housing and facing the back of the car:
a) You can see these pegs and brackets on your left hand side if you pull the light housing GENTLY outward. The pegs are pointing into the vehicle from the left side of the car and stick into holes. There is also a spring bracket holding the housing on where the screws are.
b) To remove the housing from the brackets, push/pull the right side of the lamp housing outward and to the left. Do this carefully so that you do not break any of the plastic pegs. What you are looking to do is detach the housing from the spring bracket, and then push/pull the pegs from their holes. You are simply rotating the lamp housing out of the brackets.
Simply mirror instructions for removal of passenger side housing.
Replacement:
This part is a little easier. Line the pegs up with the holes, and then push gently to line up spring bracket with it's hole. Then, push with a little force to get the spring in the hole. Make sure the pegs are in their holes or else it will be crooked and loose.
Take your time! You do not want to break the plastic. It should eventually come loose. With any plastic on your vehicle, be careful not to force it. Good luck!
Read more: http://wiki.answers.com/Q/How_do_you_replace_the_tail_light_assembly_on_a_2000_Ford_Focus_SE_Station_Wagon#ixzz197C2shUn
Dec 25, 2010 | 2000 Ford Focus
Cord doesn't retract, so I took it apart ...
Pardon the long winded answer. I have had a similar same issue on this trimmer TWICE in the first 3 months. What I found on my trimmer is that there is a spring buffer/assist built into the starter assy between the rope pulley and the plastic part that engages the cogs on the motor. The plastic part that engages the motor has a hole in it to retain one end of the spring and the other end of the spring fits in a slot in the rope pulley. The plastic part with the hole appears to be poorly designed and allows the spring assist spring to fall out of the hole and jam the entire assembly preventing the rope from returning. Pulling it apart allows the recoil spring to escape from under it's cover and prevents it from engaging. Yes, removing the spring can be a little exciting -- take your time and cover the housing opening with a towel before removng the spring to keep it from flying across the room. I rewound the spring by driving a nail into my workbench and using it to retain the center hole and wound the spring until it would fit inside the metal spring cover. There's a bump in the outer winding that fits in a hole in the spring cover and then it slides over a peg in the plastic housing. The cover will retain the spring as you put it back into the housing as long as you take your time. The circled inner end of the spring should show in the center hole and it engages the other part of the recoil assembly that engages the cogs on the motor. Check to see if the assist spring is engaged on both ends before tightening the 3 retainers. All-in-all a pretty poor design that has me looking for another trimmer and this one's going in the trash.
Aug 07, 2009 | Homelite Mighty Lite Lawn Trimmer
How do u erect a lichfield challenger 5 tent ?
Peg out 2 back pegs of inner tent. Peg out 2 front then side pegs. Place smaller pointed pole through hole at bell end of inner tent from inside, longer pole through hole at front.Fit protective bases to each pole. Top pointed poles with separators. Assemble roof pole, put through loop and over separators. Throw outer tent over from bell end (needs 2 people) then carefully lead towards front til holes in roof match - back hole first. Fit rain hoods front and back. Peg outer tent from bell end first then back corners, front corners then sides. Place porch poles through holes at front of porch, zip door sides down with one person holding poles upright and taut and peg out door. Peg sides all along making sure they do not touch inner tent. Fix guy ropes.
Aug 06, 2009 | Sport & Outdoor - Others
Waltec washerless faucets
i cant draw it for you but the spring fits inside the seat and the seat goes in the hole last. in the hole goes the spring then the seat goes on top then the stem.put the seat on a small screw driver,then the spring then slide it all into hole, try it good luck.
Mar 13, 2009 | Plumbing
MVOHD70 DVD player re-installation
Wherever your overhead dome light is, you will be using the wire harnesses appropriate for the connections. The wire connectors will only fit the appropriate connectors. The best way to attach the DVD player to your ceiling is to screw a wooden block (8" W x 6" L, with the length of the block being width) using self-tapping metal screws. There should be a metal cross-member in the ceiling that will permit you to attach the wooden block with the self-tapping metal screws, or you can use a drill to make pilot holes in the metal cross-member and wood, but you will have to make sure that the holes are aligned. Once you have attached the wooden block, you will have to attach the DVD player by opening the screen and finding the screw holes through the main body of the DVD player. You can then use wood screws in the holes to attach the DVD player. If you have any other question concerning this matter, please post here again requesting MTM help.
Sep 27, 2008 | Liquid Video MVOHD80 Car DVD Player
On switch
This IS tricky. You have to place the "L" shaped pin of the spring into the hole in the middle of the wooden looking contact switch. Then put the zigzaggy end of the spring into the hole in the on/off switch. Place the big hole of the wooden looking over the dowel on the "switch" side. Now the trick is to do all this and hold it together while replacing the top magnetic part of the motor. This will hold it in place. Them put the rest of the motor in. screw and your done. Hope this was helpful
Sep 09, 2008 | Oster T-Finisher 76059-010 / 76059-030...
Hotpoint DWF61 Soap tray
What usually happens with this machine is the peg that the spring attaches to breaks. You will need to drill a small hole into a nearby plastic tab and attach one end of the spring into this hole. Job done.
Sep 30, 2007 | Hotpoint 24 in. DWF61 Built-in Dishwasher
Evenflo Jenny Lind Crib Logo
66 people viewed this question
Top Evenflo Baby Gear Experts
Colin Stickland
Colin Stickland
Rob Sinbad
Rob Sinbad
Stitch85
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
