Question about Samsung PN Televison & Video
I replaced both y-sus and x-sus and the screen comes on fine for a while then turns to snowy white and blurry
Pn50b430p2dxza
3 Suggested Answers
SOURCE:
skistockli
  • 73 Answers
SOURCE: black screen, sound ok. i replace y sus and z sus on pl4260n
Join our group. We all have the same problems with this TV. HP sold it with a faulty board. We the consumers are taking action. Contact us at: dorje@forexcafe.org
Posted on Jul 11, 2009
SD Tech
  • 14553 Answers
SOURCE: y sus board buzzing
Glad you resolved it.
Posted on May 17, 2012
Sony TV model KDL-40V4100. What could cause a snowy white screen?
Tuner has to be checked and replaced. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 08, 2015 | Sony Televison & Video
Lg plasma DT50py10. When turning on bottom half of screen is snowy and has lots of white lines for approx 20 min then it goes away. Top half of screen is normal
sounds like your bottom buffer board is on its way out .
Will also need to check the y sus board as this some times causes the buffers boards to fail.
May 24, 2011 | LG DU-50PX10 50 in. Plasma HDTV
KP-43170 Sony Projection TV is blurry
Try this site www.my.electronicshelponline.com they have list of free schematic diagrams/service manuals including repair and troubleshooting tips. Good luck. Hope this help.
Jan 26, 2010 | Sony KP-51WS500 51" Rear Projection...
Power but no picture
the Y-SUS BOARD is for picture in tv.if the picture is not coming or not proper the Y-SUS board needs replacing .but if the picture is blurry or with linings reparing helps.but in your case the tv does not turns on with y-sus board connected only error led comes on.this means y-sus board needs replacement.
you can get it from www.partstore.com
if you are not familiar with replacing the y-sus board its advisable to get it done by local tv repair technician familiar with your brand/model.
This will help. Thanks please keep updated.please do rate the solution if helped.thank you for using fixya.
Oct 26, 2009 | Toshiba 50H72 50" Rear Projection...
LCD screen and small viewfinder screen go snowy than white. When I turn the camera on the LCD worked fine, when I than turn it, it was just white. Now it won't even turn on normal. I can still make...
Go to your menus, set all to factory settings or default.
Test the camera by using more of the settings, and notice how it works.
The LCD settings especially are what you want to make sure are set right...not too bright, and of course not too dim either.
Sep 25, 2009 | Canon Cameras
T MOBILE MDA VERY WHITE BLURRY SCREEN
Its due to humidity or water. Due to the lack of resources its cheaper or replace than repair.
Feb 13, 2008 | T-Mobile MDA
AVIC-N2 screen only works sometimes
Contact Pioneer for Possible free service if the failure is a Flex cable which is most likely is
800-421-1603
AVIC cable upgrade
Dec 10, 2007 | Pioneer AVIC-N2 Car DVD Player
Snowy Picture, Toshiba 42HP84 plasma tv
Similar problem with my Toshiba. I was told it was the power supply and that it would cost about $900 to replace parts and labor
Nov 21, 2007 | Toshiba 42HP84 42 in. Plasma HDTV
Blue screen with white snowy circle in the middle of screen
Sounds like bad capacitors
Replacing the C9A37 & C9A38 caps or
problems with some capacitors on the pwd power board, and that it would be good to change them if they were swollen
Oct 20, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
121 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
