When the oven is turned off the blower and heating element stay on .The electric breaker has to be thrown to shut oven off
Good Morning Friend,
I understand your Frigidaire oven will not turn off. I also see that when you turn it off, the blower and heating element, stay on. The blower will stay on to help cool down the oven, but the heating element should turn off. I see that you have to turn your oven off at the circuit breaker. I suggest contacting your local authorized dealer for further assistance. They will be able to diagnose your appliance and determine why your oven will not turn off. Hope this is helpful.
-Best Regards-
WP
SOURCE: electric oven too hot
difficult to see what you have done here! can you come back with some info: do you have an earth trip fitted in your consumer unit? how many wires are fitted to the element? did you touch any other wiring except those connected to the element?
SOURCE: jenn air oven won't turn off
Maybe, if you have a mechanical type of thermostat. Could also be the circuit board. Wonder why you blew the breaker in the first place. If the unit is digital, the thermostat is really a sensor, a relay and assorted electronics. The relay and electronics are on a circuit board. That's what you're going to be buying.
SOURCE: Frigidaire GM deluxe electri dean (electric oven wall unit)
if you feel through the insulation you can find the two wires that attach to the element pull them through to plug the element back on but there is no plug per say but first are you sure the element is good were there no wires on the element when you removed it should have been two spade connectors with wires on them attached to the element hold my rating till you reply
SOURCE: KitchenAid KERA807PSS01 oven won't shut off until breaker thrown
assuming its a stainless stell oven? if so heres the par tyou need its a membrane switch( your cancel button ceased to operate corrrect???not a bad part to install you need to remove a few screws from under control panel itself( perhaps a few on the sides, the front control will lift off and this part is installed from behind the control panel (SHUT THE BREAKER(S))
part number 9756595ES
in the mean time instead of shuttin off the breaker toreset you can simply( requires reading manual ) set your oven to time bake. it will shut off automatically after predetermined time has been obtained.
Testimonial: "worked, thanks"
SOURCE: Thermador SC301T heating elements not working (top
Its the thermal safety switch. When it trips - it cuts any power from reaching BOTH elements. Open the oven door - at the top wehere the oven latch is - remove the long black panel. In the middle - on the right is a small cylindrical switch...push down on the top - in the very center...it will rest the switch (like a circuit breaker) and then reassemble. Just did it on mine (2nd time) and it fired right up. Good luck
