1) test the outlet wall with a desklamp, if the lamp turn On THE circuit is o.k otherwise, the problem is fuse blown or c. breaker tripped, reset or replace fuse.
2) test the power cord for open or faulty. with VOM usin continuity
3) test the fuse y/o c.breaker inside of machine and reset or replace.
4) Turn on the machine if the machine keep the same simpton, test the key(magnet) the key is a magnet, test vs your magnet from seal magnet of your refrigerator for atraction or repulsion, if doesnot pass the test replace the magnet from some hardware like home depot.
and PROOF again, can be work. see the block,
Otherwise if the problem keep you must call some tech profesional, maybe you have Main switch open or defective and need replace, or power supply, capacitor, transformer, etc defective. or faulty.
God bless you
