I leveled per instructions. Shakes bad with small loads. checked springs on bottom of tub they are all connected.
Good Afternoon Rob,
I understand your Frigidaire washer, model# FAHE4044mw0, shakes in the spin cycle, even after making sure your appliance is leveled. I also see that this occurs with small loads. Please make sure that your load is evenly distributed. If not, stop your washer and redistribute the load. Also make sure that the load is not too small. Try adding 1 or 2 similar items to even out the load. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
SOURCE: kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
SOURCE: kenmore washer series 70 shakes wildly during spin during cycle
I have the same kenmore and have experience this before. It is unbalanced. Get a spirit level to check for balance. To rebalance, empty the washer (so it's not heavy), lean over the washer and grab the back, tilt it forward and the auto balancing legs should reposition themselves. Re-check for balance using the spirit level. If still out, adjust the front feet of the washer by screwing the legs up or down (using a wrench). This will cure the problem (unless you have a very unbalanced load of towels for instance). Good luck
SOURCE: Matag washer Performa shakes badly on spin cycle
Ensure the washer is level by rocking it. If its level should'nt be able to move. You may have a weak floor. to checks this look to see if anything is vibrating around the washer.
SOURCE: whirlpool washer machine shakes badly when cycle
The problem could an improper leveling of the machine.Also could be bad drum bearings or even damaged ones because of the previous heavy spins.
SOURCE: HAVE A LG TROMM FRONT LOADING WASHING MACHINE THAT SHAKES WHEN SI
Front loaders are prone to vibration problems. Don't want to go into the technical details of why, but it's important that they're placed on very solid surface (preferably concrete or tile), and checked that their feet have been adjusted so that the machine is level. Unfortunately, most people don't have a concrete pad for their washer. One simple option to consider is to provide dampening of the vibrations. This can be done very simply as shown here. The main thing to keep in mind with this solution is that it is merely trying to dampen the vibrations. Don't be too forceful in your own solution (think lightly touching the top of a vibrating tuning fork with your finger to stop the tone).
Hi
First check if the machine is level .Also makes sure you do not have an unbalanced load. Lint filter between the tubs is loose/broken, tub nut and drive block is worn, bad brake, worn spin tub are some various reasons when washer shakes in spin cycle.
Please check the bellow link to troubleshoot your problem:-
http://www.wikihow.com/Fix-a-Shaking-Washing-Machine
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
