It does not hold any charge as it is dead
A compatible battery can be found at shaveroutlet.com using the link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
SOURCE: my rechargeable shaver HQ5812/16, needs
You will find the correct battery at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
SOURCE: does not keep its charge.I was hoping to fit new
The manual does not show you how to replace the battery as it is not intended for the user to change. To change, first remove the two screws on the back to remove the back cover and access the battery. For easiest replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
You will find the correct battery for your model at shaveroutlet.com. See link below
