Sewing Machines Logo
A
Anonymous Posted on Jul 02, 2014
Can't get Juki tension right
Lu 1508nh
Bill Boyd
Level 3:
Top Expert:
  • Juki Master 53,816 Answers
  • Posted on Sep 03, 2015
Bill Boyd
Juki Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11925663
Points
172802
Which tension is wrong
if thread is bunching up under material increase the tension of the needle thread if the bottom thread is loose then increase the bobbin thread tension
each thread result for above or below material will indicate which thread to alter the tension on
5 Related Answers
miguelalvara
  • 109 Answers
  • Posted on Aug 15, 2009
SOURCE: I need a manual for a JUKI LU 563
JUST check at google ,com manuals
and then write you model# or you can go directly to your manufactury on line or if you heve costumer service # call them
Wayne Buss
  • 121 Answers
  • Posted on May 02, 2010
SOURCE: Tension settings juki mo-644d
-If the machine is threaded correctly and the thread is flossed into the tension discs,
-if the thread is high quality and not cheap thred
the top tensions should be at 5-6 and the looper tensions should be at 4-5
Be sure it is threaded correctly (follow the threading map on the inside of the front cover of machine
Also be sure you are using a size 14 or size 90 standard Schmetz needle do not use Klasse needles
as these are to short and affecdt the timing.
drtension
Anonymous
  • 517 Answers
  • Posted on Jun 16, 2011
SOURCE: I have a Juki LU-563.
Good day to you!!!
I am suggesting you to put an oil in parts which need it so that it become smooth to use..
I hope it works...
for any questions please feel free to contact me,...
Thank you po!!!
abozid
TCHNICAL SUPPORT FOR JUKI-JACK-PEGASUS
  • 180 Answers
  • Posted on Jun 22, 2011
SOURCE: How do I change the stitch length in my Juki LU
hi there
the graduation of the stitch length is marked on the feed graduation plate attached t the main shaft,to adjust the stitch length rotate the hand wheel slowly as you keep pressing the push - button stop the bed until the tip of the push- button enter groove of the accentric mechanism, when it is entered rotate the hand wheel eigher towards you or away from you as you keep pressing the push - button until the desired stitch length indicating mark on the graduation plate appears on the hole of arm. when appear release the push - button and check stitch length.
BEST REGARDS
AHRAF ABOZID
CAIRO - EGYPT
bargainbox
Hassy
  • 1388 Answers
  • Posted on Nov 10, 2011
SOURCE: instructions
try sewusa
I have a new Juki LU 1508NH and I can't get it to pick up the bobbin thread. Any ideas?
There are a few things you can try -
1. Extend the bobbin thread longer outside and push it away from you.
2. When you make the Stiching pressure lever down then see whether it sits properly or is lose and creating gap.
3. Clean the bobbin seat. Check for its free movement.
Sewing machines i cant get my juki lu 562 to make a single stitch nothing
Try installing a brand new needle. If it still will not pick up the bobbin thread, the machine may be knocked out of time. Take it for service.
Help plz. my juki lu 562 wont sew
Not enough information to provide an answer.
2answers
I have a juki lu 562. Adjusting stitch length. For some reason it will not go to 9, 10, , 11 on scale. Will not go any farther than 8, then turning wheel opposite goes to 12.
Turn it to either extreme and then see if the feed dogs hit the plate when you hand turn the hand wheel towards you. Sometimes the feed dogs or plate have been replaced and they have set the stich length so that the feed dogs won't hit the ends of the plate.
1helpful
My Juki LU-563 stopped picking up the bobbin thread, changed needle, took out bobbincase to look for thread, none, still won't sew because of bobbin thread not being picked up.
If you've properly installed a brand new needle that is correct for the machine, threaded it correctly, checked that the bobbin is installed correctly and the bobbin tension threaded properly, most likely the machine is out of time. In other words, the needle is arriving at the bobbin at the wrong time in order to intercept the bobbin. (You can open the bobbin area, hand rotate the handwheel and watch how and where the needle moves in relation to the bobbin to see where and why it is not connecting.) You can search the internet for web sites and videos that discuss machine timing or you can take it for service.
The Bobbin Assembly will turn in reverse but not forward Juki LU-563
Most likely the bobbin retainer has been bent. Turn it over by hand with the power off and look carefully, you will prolly see it.
I need a manual for Juki LU-1508 sewing machine. Can any one help?
contact a juki dealer about a manual
email these sites about a manual
sewingpartsonline.com
sewusa.com
sewvacdoctor.com
a1sewingmachines.com
sewingmachines.com
I have a Juki LU-562 sewing machine I was sewing thick leather it made this clunk noise and a spring flew out of it underneth it now the hook just turns and it doesn't sew.
Like most of the older sewing machines, the lu-562 is usually an easy fix when it comes to issues of timing and even broken parts. First determine where the spring came from and that should point you to the parts that need replacing and/or readjusting. But, by all means DO NOT continue operating the machine until its fixed. Without actually seeing the machine, it sounds as if the needle bar spring failed.
6helpful
4answers
Looking for a manual
JUKI HOME SEWING DIVISION 8500 NW 17 th Street Miami, FL 33126 Phone: (305) 594-0059 [email protected] she will send you one
Top Juki Sewing Machines Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
