Samsung Jet S8000  Cell Phone Logo
A
Anonymous Posted on Jul 02, 2014
How to set up gmail pop3 in computer - Samsung Jet S8000 Cell Phone
Magic Mail (in Magic Desktop) doesn't work with Gmail account. The message is "error adressed" My settings: [email protected] [email protected] + autentication smtp port:465 pop3 port: 993
I downloaded and installed Magic Desktop and configured Magic Mail. It works with Gmail, but it seems to only support the POP3 server for Gmail. In other words, you must use pop.gmail.com, not imap.gmail.com. You also need to enable POP email in your Gmail settings.
Hope this helps, Eric
tip
Gmail on outlook!
To use your Gmail e-mail account in Outlook, you must first make sure POP3 support is enabled in Gmail, and then you can add it to Outlook.
Log in to your Gmail account.
At the top of any Gmail page, click Settings.
In the Mail Settings window, click Forwarding and POP.
I don't see Forwarding and POP
Gmail is turning on POP3 support for users in phases. If Forwarding and POP does not appear, your Gmail account cannot be configured for POP3
support.
In the POP Download section, select Enable POP or all mail or Enable POP only for mail that arrives from now on.
Click Save Settings.
In Outlook, on the Tools menu, click E-mail Accounts.
Click Add a new e-mail account, and then click Next.
Click POP3, and then click Next.
Under User Information, do the following:
In the Your Name box, type your full name the way you want it to appear to other people.
In the E-mail Address box, type your e-mail user name followed by @gmail.com.
Under Server Information, do the following:
In the Incoming mail server (POP3) box, type pop.gmail.com.
In the Outgoing mail server (SMTP) box, type smtp.Gmail.com.
Under Logon Information, do the following:
In the User Name box, type your full e-mail address, including @gmail.com.
In the Password box, type your password.
Select the Remember password check box.
Note You have the option to have Outlook remember your password by typing it in the Password box and selecting the Remember password check
box. Having Outlook remember your password means that you won't have to type your password each time you access the account; however, it also
means that the account is vulnerable to anyone who has access to your computer. Use strong passwords that combine upper- and lowercase letters,
numbers, and symbols. Weak passwords don't mix these elements. Strong password: Y6dh!et5. Weak password: House27. Use a strong password
that you can remember so that you don't have to write it down.
Click More Settings.
On the General tab, under Mail Account, type Gmail.
Click the Outgoing Server tab, and then select the My outgoing server (SMTP) requires authentication check box.
Select Use same settings as my incoming mail server.
Click the Advanced tab, and then under Server Port Numbers for both Incoming server (POP3) and Outgoing server (SMTP), select the This server
requires an encrypted connection (SSL) check boxes.
Change the Outgoing server (SMTP) port number to 465.
The Incoming server (POP3) port number should change automatically to 995 when you select the This server requires an encrypted connection (SSL)
check box.
Click OK.
To verify that your account is working, click Test Account Settings. If there is missing or incorrect information, such as your password, you will be
prompted to supply or correct it. Make sure your computer is connected to the Internet.
Click Next, and then click Finish.
Notes
Do not select the Log on using Secure Password Authentication (SPA) check box.
Unless specified by Gmail, all server and address entries are typed in lowercase letters.
This works for both Outlook 2003 and 2007!
2helpful
Hi how do i cofigure my samsung corby pro for e-mails? please help
I have research and found the following solutions,I haven't tried them for my self yet but they seem to be solving the problem.
Go to menu/settings/application settings/message/email/email account/create account and follow the instructions below
Account Name: (your Gmail id) SMPT Server: smpt.gmail.com SMPT Port: 465 Secure Connection: SSL Incoming Server Type: POP3 POP3 server: pop.gmail.com POP3 port: 995 APOP login: no Secure connection: SSL Download limit: 500 IMAP4 incoming email: disable Retrieving option: subject only Keep on server: yes My email address: (your Gmail id) Username: (your mail id) Password: ********* POP before SMPT: no SMPT path: yes Same as POP3/IMAP4: yes User name: disabled Password: disable
If you want to set up your other accounts such as yahoo and hotmail, then just change the things given below, and leave the rest as it is.
Server settings for hotmail: Server (SMPT) - smpt.live.com SMPT Port - 25 Secure connection: SSL POP3 server: - pop3.live.com POP3 Port - 995
Server settings for yahoo: Server (SMPT) - smpt.mail.yahoo.com SMPT Port - 25 Secure Connection - SSL POP3 server - pop.mail.yahoo.com POP3 port - 110
Have a great day!
http://www.pdxcellservices.com
free phones with contract plans and upgrades
4helpful
How configure e-mail setup in GT-S5233S set
OTE : VERY FIRST ENABLE POP3 FROM YOUR GMAIL ACCOUNT SETTINGS. LOG IN TO YOUR GMAIL ACCOUNT > ON TOP RIGHT CLICK ON SETTINGS >THEN CLICK FORWARDING & POP3 > THEN ENABLE POP3 FOR ALL MAIL OR YOU CAN SELECT OTHER OPTION. BUT AT LEAST POP3 MUST BE ENABLED. THEN SAVE CHANGES. POP3 Gmail Settings For Samsung Star Cellphones:
Go To > Menu > Messages
Click Settings > Email
Then Touch >Email Setup Wizard
Notice will ocuur Touch > OK
Give name to your account E.g Gmail
Enter your email id : [email protected] , Then Enter Password for your account.
Incoming Server type : POP3
Incoming Server : pop.gmail.com
Outgoing Server SMTP : smtp.gmail.com
Secured Connection : Off
Then touch OK & it will display your POP3email account configured successfully. Now press back button and tap on Email Accounts, then touch the email account you have just created. There some more option than above you just have to edit that.
Secured Connection: Off
POP3 Port: 995
SMTP Port : 587
Now, Tick The option APOP Login.
Download Limit: 500
Secured connection: SSL (Choose SSL for second option only & not for first option.)
Retrieving Option: Choose Subject only
Keep On Server: Tick
My Address: yourname @gmail.com
Username /Password : same as you entered above
POP before SMTP : Dont Tick
SMTP Auth: Tick
Same as POP3/IMAP4 : Tick
And Finally Save All Settings.
That's it !!!, Now you can retrieve your message from your mail box & Click on Download to download all messages.
If you want your Samsung star phone to automatically download your messages ? Here is a small option they have given for that.
Go To Message > Settings > Email > Receiving Options
Download Limit: 300KB
Auto polling: Home Network Only
Following option is time after when email is downloaded automatically.
Polling Frequency: 30 Minutes (you can choose higher if you want)
Send read report: Tick
And again your emails will be automatically recovered from server at every 30 minutes. And you'll get notified near your message notifier on your home screen if there is any unread emails.
2helpful
I own a samsung GT I 9000. Have been trying to synchronize with my corporate mail server without success in spite of following the screen tips. Could you please help me or atleast guide me to a custormer...
Check the security settings of your mail server to ensure you're not being blocked.
Here are some 'standard' settings that may work with your system.
Gmail Incoming Outgoing
Access Type Web & POP3 Web & POP3
Email Address Format [email protected] [email protected]
Account Username Format
Full email address Full email address
Server Address pop.gmail.com
Use SSL: yes Port:995 smtp.gmail.com
Use SSL: yes Port:465
Hotmail Incoming Outgoing
Server Address pop3.live.com smtp.live.com
ic24 Incoming Outgoing
Server Address mail.totalise.co.uk smtp.tiscali.co.uk
UKGateway Incoming Outgoing
Server Address pop.ukgateway.net smtp.ukgateway.net
UK Online Incoming Outgoing
Server Address pop3.ukonline.co.uk smtp.ukonline.co.uk
Vippowerent Incoming Outgoing
Server Address pop.vppn.com
Virgin.net Incoming Outgoing
Username Username
Server Address mail.virgin.net mail.virgin.net
Wanadoo Incoming Outgoing
Email Address Format username@ name.wanadoo.co.uk username@ name.wanadoo.co.uk
name.wanadoo.co.uk name.wanadoo.co.uk
Server Address pop.wanadoo.co.uk smtp.wanadooasdl.co.uk
World Online Incoming Outgoing
Email Address Format username@ worldonline.co.uk username@ worldonline.co.uk
Server Address pop.
tiscali.co.uk smtp.
tiscali.co.uk
Yahoo.co.uk Incoming Outgoing
Username Username
Server Address pop.mail.yahoo.co.uk smtp.mail.yahoo.co.uk
Yahoo.com Incoming Outgoing
Username Username
Server Address pop.mail.yahoo.com smtp.mail.yahoo.com
Settings - E-mail
You'll need to complete all steps for this to work. Make sure that if you have to enter O2 in the settings you use the letter O and not a zero.
The following settings are if you use O2 Email as your ISP (Internet Service Provider).
If you require different settings eg Yahoo, Gmail etc please click here
1. Tap the Application tab on the bottom of the screen
2. Tap Email
3. Tap Next on the Welcome to Email setup screen
4. Tap on the Email address text box and enter your Email address then tap Done
5. Tap on the Password text box and enter your Password for your Email account then tap Done
6. Tap Next
7. Your phone will now try and download your setting to your phone and set up your account, if this can not be done you will see the message, Setup could not finish. Unable to open connection to server. Tap Edit details to continue.
8. Tap Manual setup
9. Tap the Username text box and enter your full Email address then tap Done
10. Tap POP3 account
11. Highlight POP3 server and tap the text box and enter mail.o2.co.uk
12. Check that Port is default set at 110
13. Highlight Next and tap
14. The phone will now check your settings
15. Tap the SMTP server text box and enter smtp.o2.co.uk
16. Highlight Next and tap
17. The phone will now check your settings
18. Tap Next on the Account options screen
19. You now have the options to add a name for your new account plus add your name to outgoing messages
20. Tap Done
How to define email profile
GO ON EMAIL SETTINGS
account name: Gmail SMTP server: imap.gmail.com SMTP port: 465 secure connection: SSL Incoming server type: Pop3 Pop3 sever: pop.gmail.com APOP Login : ticked Secure Connection: SSL Download limit: 500 Retreive option : whole messge Keep on server: ticked my email address: *****@gmail.com username:*****@gmail.com pssword: **** POP before SMTP: unticked SMTP auth: ticked SAme as POP3/IMAP: ticked
1helpful
I've done exactly what was said above to set my Samsung to receive hotmail emails but now when I click on download it says "Define Email Profiles" What am I doing wrong? Can someone also tell me...
I solved similar problem, Follow settings given below
Account Name: @gmail.com
SMTP server: smtp.gmail.com
SMTP port: 587
Incoming server type: POP3
POP3 port: 995
Download limit: 50
IMAP4 Incoming email
Retrieving option: Subject only
My address: @gmail.com
User name: @gmail.com
Password: **********
POP before SMTP: tick
SMTP auth: tick
Same as POP3/IMAP: untick
Now set ur Connection. Restart phone once... it works wonderfully
cheers !!
hope u like it njoy
6helpful
2answers
How to configure email for samsung gt-b5310
GO TO UR GMAIL ACCOUNT SETTING AND ENABLE IMAP. account name: Gmail SMTP server: imap.gmail.com SMTP port: 465 secure connection: SSL Incoming server type: Pop3 Pop3 sever: pop.gmail.com APOP Login : ticked Secure Connection: SSL Download limit: 500 Retreive option : whole messge Keep on server: ticked my email address: *****@gmail.com username:*****@gmail.com pssword: **** POP before SMTP: unticked SMTP auth: ticked SAme as POP3/IMAP: ticked
Can someone please walk me through how to set up a minolta c351 scan to email. I am using gmail for the pop3 settings but for some reason i keep getting the serever connect error message. I have used the...
your pop3 settings should not need a number after them...you should contact your email provider for the settings....or if you use outlook, you can go to tools, account settings, and see the settings for your email there...
4helpful
2answers
Gmail POP3 Error
Set your gmail profile in your gmail account, by allowed pop3 system software download your mail from gmail
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
