Good Afternoon Friend,
I understand that you want to know if any water should remain under the glass trap, on your Frigidaire dishwasher, after the cycle has finished. Per the owner's manual, "it is normal to see a small amount of water under the filter at the end of a cycle." Hope this is helpful.
-Best Regards-
WP
SOURCE: Frigidaire dishwasher dirty & sticks in cycle
First, check the holes on the upper spray arm. They should be clear of food and debris.
Next, There's a check valve (ball) built into the motor unit. Either it's stuck, or the motor isn't pausing at the appropriate time to switch from bottom spray to top spray. You can test the check valve by opening the door momentarily while it's running. The spray noise inside should sound distinctly different. Pausing longer will switch back to the lower spray arm.
If the check valve works, you'll need a new timer.
SOURCE: Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
SOURCE: Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
SOURCE: Dishwasher will not finish cycle.
This could be one of a few things,first it sounds like it may be getting stuck on the rinse cycle,check if the water in the machine is hot if not there is either an element problem or the timer is not functioning properly,if the water is hot then it may not be draining before taking on rinse water the best way to determin if it is indeed draining and refilling is to switch the machine off ,take the drain hose and put it on the floor or in a bucket,if it drains let it finnish and then put back and switch the machine on it should fill and continue.if it does not drain then you have a blocked pipe or fualty pump,Do not reset the machine
SOURCE: Water remains in the bottom of the dishwasher
First : if this started after a new disposal was installed then you need to check the Knock out on the disposal located inside the pipe that sticks out of the disposal where you conect your dishwasher drain hose. ((((( Common Problem )))))
Ok, moving on, your dishwasher has a independent drain pump. if you know the noise of the drain pump and you do not here it. its a good chance that its bad and you can disconect it and put a volt metert to the 2 wires and check for 110V. of coures after you have your volt meter in place and ready to go you will then put your diswasher in drain and check your meter.
Here is a breakdown of a dishwasher with a simialr model number. # 60 is the drain pump.
Testimonial: "Clear and concise steps to check problem"
