SOURCE: i replaced a hp laserjet
This HP printer is comes with the USB cable. To install the printer software, you need to install the USB driver compatible to your printer and then it will ready to print.
SOURCE: how to solve hp laserjet p2015 printer problem show excamation
If you are recieving memory errors, it is because the information you are sending to the printer is too large for it's internal memory to process. There are a number of things you can do. - install more memory into the printer if your printer allows that (check your user guide) - send smaller jobs (if sending multiple page jobs - break them into smaller counts) - Make sure to use the PS driver for pdf and photo printing, and the PCL driver for plain text. Also, in the Printers and Faxes window (can be found in the control panel if it isn't on your menu) right click on the icon for your printer and select properties. Select the Advanced tab and make sure these two settings are marked - Spool print documents do document finishes printing faster - Start printing immediately
