Does your battery not start the computer up at all or it starts the computer up but something is wrong with the battery Example the battery only charges to 80% then stops chargeing? battery just can hold a charge at all etc.
It is charging the battery but the battery is not holding the charge probably from a faulty batter in the pack.so the charge is going in and out at the same time. Take the pack to a battery shop that specialises in replacement batteries to have it checked out . Take the charger also for tests.
Battery could be dead and won't hold another charge. Batteries only last for so long until you have to replace them. If you laptop is ok with the AC Adapter & Power Cord meaning it boots and allows you to work in windows, then the battery is definitely dead.
Hi, The battery needs to be replaced because it will no longer hold a charge. You can charge and charge and it will not fill up. This is called internal discharge.
need a test lite. with a friends help you can put the test lite on the small wire where it connects to the starter. if when your turn the ignition to try to start and it lites up it most likely is the starter. hope this helps
