SOURCE: brother se 400 breaking needles
The needle breaks
1. The needle is incorrectly inserted
2. The needle clamp screw is loose
3. The is bent or blunt
4. The needle is too fine for the fabric being used
SOURCE: Brother PE770 Hoop size programming stuck on small hoop option
Your machine would be able to perform 5 X 8 embroideries. The hoop size on this machine is recognized by the machine itself, depending of the embroidery file size. So it the embroidery is small, it will indicate that the small hoop is needed.
But U can use the large hoop, position the embroidery where U want then perform another embroidery on the sams hoop.
TRICK : the embroidery size exceeds the hoop? reduce it in X and or Y using this function on the machine
