Here is a link that may help. http://www.managemylife.com/mmh/lis_pdf/OWNM/L0709063.pdf
SOURCE: craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
SOURCE: I have a craftsman zts 7500 zero turning radius 26
i going to assume that yr tractor does have the hydrolic p.t.o. that controls the drive and cutting mechanism's???... if so you might start with checking the hydrolic fluid in the resevior. or you might check into replacing the hydrolic p.t.o. pump , if you ran the tractor in heavy work without any hydrolic fluid in the p.t.o. pump the pump is probably burnt up. if so im sure you can beat the cost of a new pump by rebuilding it yrself with a kit.
SOURCE: I have a craftsman ZTS 7500 w/ an electric switch
check switch and connections contacts in switch maybe damaged or corroded
SOURCE: Craftsman 22hp 7500 zero turn mower 3years old.
Be careful - running ungoverned will quickly destroy the engine. Look at the carburetor throttle lever. There should be two linkages attached -- one from the manual throttle lever, another from the governor. The linkage to the governor is usually a spring. Perhaps that came off or broke, or a foreign object is wedged in there.
SOURCE: 44" v-belt needs to be replaced
Look under footrest for diagram on sticker.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
