SOURCE: I have half a dozen
http://plantronics.custhelp.com/cgi-bin/plantronics.cfg/php/enduser/std_adp.php?p_faqid=8165&p_created=1128461658
I was searching for this today and happened to find the above on the plantronics website. It definitely frustrated me till I found out about how to put the base in pairing mode.
SOURCE: Plantronics Voyager 500a Bluetooth Headset
Try re-syncing the headset to the base unit:
SOURCE: I can't get the blue
The Plantronics 500A is the base for the 510S system, the headset may
need to be re-paired to the base unit to make sure that it has a strong
link or connection. Here are the links below for the pairing
instructions, and also the user guide.
http://www.headsetsdirect.com/pdf/Voyager%20510S%20Bluetooth%20Headset%20System%20pairing.pdf
http://www.headsetsdirect.com/pdf/510_print_en.pdf
Good luck from Headsets Direct - 800-914-7996.
SOURCE: I just purchased a Voyager
These are two different parts from Plantronics, and they don't work together. You need the 510 Replacement Headset p/n 84321-01 (see link below) to go with that base.
Plantronics 510 Replacement Headset
Good luck from Headsets Direct!
