Well since i read it often and have such a table myself, it,probably like with technics turntables. A lack of maintenance and since you s ratch with it it , only never replacing the powersupply capacitors, which are really good , but it depends all on the pressure you use .
Open the unit , check the capacitors, which is 10sec work , offcourse check the fuses and thermistor , but do you see a light if you put it on and do you hear crackles when you spin the platter and have you ever ipend the motor and clean and lubricated the motor?
A lot of peoples with the 2000 blame the motor and transformer for the thing do stop, without never have opened the unit in 14 years. It's a perfect motor and powersupply, but first open the supereasy tt
checking the obvious things. But you have to agree, it's a nice scratch unit, als the 3000 mix, which has way better abs plastic and feet, scratches better then my mk-5. And replace the plastic in the feet for mettal. I see a lot of guys with broken feet and a whole deck with scratches, but though i agree that the height adjustment, piece of far to hard plastic toyshit, most peoples use the pitch far too high,
But in 14 years stuff breaks
SOURCE: my turntable keeps skiping for no reason, no
Don't forget that the tone arm is too short and the material too heavy, i like vestax, but a bit wrong angle with too much pressure messes up your records fast.
