Hi everybody, my name is Jose and a friend of mine has an old Xerox Docucolor 3535 giving an error code 116 201. We have replaced the damaged hard disk but we don't know how to recover original data. Is it possible to find an ISO image to rebuild the system? Moreover, is there any manual or tutorial explaining how do a full system restore? Thank you in advance for your help. Regards
SOURCE: xerox docucolor 3535 116-321 error
Unplug the ethernet cable, If it does not come up with the code then.
Search for something like internet printing turned on somewhere.
That's a freaky code that normally is associated with some odd ball print job being sent to the printer, or something trying to access the network address. It is a pain sometimes to diagnose.
SOURCE: Xerox DocuColor 3535 103-208 error I accidentaly
There isn't much you can do, except perhaps buy at least one new board. But those are expensive
In this case, a better solution is to call Xerox. This correction must be done by an Authorized Xerox technician, with their proprietary laptop called a PWS.
They will run the procedure called GP-10 Replacing Billing PWBs.
Whit
Item, Inc.
SOURCE: Xerox DocuColor 3535 Copier Problem
116-325 RAP An error occurred in ESS fan rotation:---------Try reset procedure:--
to correct your issue:
Simultaneously press and hold the 1, the Stop, and the Power Save buttons on the Control Panel.
If the problem persists try:
Hold the 6, the Stop, and the Power Save buttons.If still it comes again,---------
Hold the 4, the Stop, and the Power Save buttons .If still it comes again ,-------
Hold the 3, the Stop, and the Power Save buttons .If still it comes again then there is internal problem with cooling fan .The ESS fan module has to be replaced.The part number for ESS fan module is
127K32920.To order this part you can order it from online website.click this link directly to order the parts:---
http://www.iteminc.com/parts_docucolor_1632_2240.htm
this will help.Thanks.Helpmech.
