A knocking noise coming from the rear roller of a Urevo treadmill can be caused by several issues. The following are some troubleshooting steps you can try:
- Check for loose bolts: Make sure that all bolts and screws that hold the frame and the roller in place are tight and secure.
- Check the belt tension: Ensure that the belt is tight enough. If the belt is too loose, it can cause knocking and other noise issues.
- Check the rollers: Make sure the rollers are not worn or damaged, as they support the weight of the belt and can affect the alignment of the belt.
- Check the deck: Make sure the deck is not damaged or worn, as this can cause noise issues as well.
If the noise persists after trying these steps, it's best to stop using the machine and seek assistance from the manufacturer or a professional repair technician. Using a machine that is making a knocking noise could potentially be dangerous and lead to further damage.
