1. To enter the Service Alignment Mode (SAM), press the following key sequence on the remote control transmitter: 0-6-2-5-9-6-Status.
2. From the top level SAM menu, use the Menu Up/Down keys to highlight the Geometry sub menu.
3. Use the Menu Left/Right keys to enter the Geometry sub menu.
4. In the Geometry sub-menu, use the Menu Up/Down buttons to select VAM.
5. Using the Menu Left/Right keys, adjust VSH so that the horizontal bar is properly centered, top to bottom.
6. Using the cursor up/down keys, select VAM from the Geometry sub-menu, and use the Menu Right key to
increase the value to obtain a slight overscan.
7. If other Geometry adjustments are needed, proceed to the necessary adjustment using the Menu Up/Down
buttons.
8. Upon completion of Geometry adjustments, press the Menu button to return to the top level SAM menu.
9. To exit the Service Alignment Mode, turn the set off with the Power button on the remote control.
