Good Afternoon Friend,
I understand that your Electrolux washer, model# EWFLW65HIW, has water left in the soap dispenser. This is typical for your particular model. The soap and fabric softener area are set up on what is called a siphoning system. This means that when it is time for the soap to release it will release and run water through the area. If the mechanism closes before the water is done running through, you can have water left in the soap dispenser. Hope this is helpful.
-Best Regards-
WP
SOURCE: wet clothes, water in soap dispenser
Next check your drain, where the hose goes in behind, snake this out. And dont shove the hose in too deep, into the standpipe that is.
If this helps, rate me please.
SOURCE: soap dispenser not working
It sounds like the water valve has a clogged filter. Shut the cold water to the washer off, disconnect the hose and remove the filter screen in the washer water valve. Clean out the filter with toothbrush. Reinstall and everything should be ok.
SOURCE: water comes out of soap dispenser
http://www.applianceaid.com/neptune.html
click this link and click the required option in the link
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
SOURCE: water leaking into soap dispenser when machine off
faulty water valve turn both off to see if it stops then turn on one at a time if it leaks thats it
SOURCE: soap dispenser overflows with water...
Need to know how old machine is etc. dispenser could be clogged.
I appreciate your post, friend!
Based off the information you have provided you still have water inside of the dispenser of your Electrolux washer. This is a normal operation of your washer. This is due to the siphoning action of your dispenser and washer. You may need to empty the dispenser every once in a while due to the water left inside of it. I hope this information is helpful. -Matt
Thank you for your inquiry, cheryl!
I understand that you have removed your soap dispenser on your Electrolux washer and are having a challenge getting it back into place. It should go back into place once lined up. If you continue you having an issue I would suggest having a professional technician out to your home for proper install of the dispenser. Good luck. -Matt
