contact the manufacture or manufacturers distributors or authorized service agents to get the part
if they are not handy then take the part into an electrical wholesale shed and they may have a replacement part for you
after all white rogers will not make relays but will use brands off the shelf on their assembly line
www.manualagent.com > White Rodgers Manuals > 1F56N-444
White Rodgers 1F56N-444 PDF User's Manual Download & Online Preview. ... Download Air Conditioners User's Manual of White Rodgers 1F56N-444 for free. .....Set anticipator to match the setting of your old thermostat you noted in Step 3, ..
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. After replacing the battery you need to do the reset operation. If you need further assistance please contact us at 1800-284-2925.
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. Reset the unit by pressing UP, DOWN and TIME buttons all at the same time. The unit will go blank for a couple of second then operate the unit. If this did not resolved the problem contact us directly at 18002842925.
follow this guide:
Diagnostic: Set SYSTEM Switch to HEAT and raise the setpoint above room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation. If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating is operating correctly.
how old is this dryer and what is the model number
email this and i will see what i can do [email protected]
if the dryers not to old it could be the little white fuse sencer on the back by the thermostate good luck
