Just leave it for 10 mins unplugged without the batteries in it.
If you need a manual to re-program it, one of the users has one here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-S400_Operation_and_Programming_manual.html
SOURCE: I bought a second hand register casio se-s300. can
Turn key to PROGRAM mode.
Turn power off at wall.
Hold FEED down - keep your finger on it.
Turn power on at wall.
Wait 5 seconds, then let go of FEED.
Press SUBTOTAL.
After power on. You are ready to get going.
SOURCE: How to reset factory settings on a Casio SE-S300
How do I reset the cash register? 116ER, 117ER, CE2300, CE2350, CE2400, CE280, CE285, CE300, PCR202, PCR204, PCR308, PCR408, PCR350, PCR355, PCR360, PCR365, PCR450, PCR460 This will erase all information - Remove AA batteries and unplug register from wall for 15 minutes.* If resetting does not work this indicates issue is repair level. PCRT465, PCR465A, PCRT2000, This will erase all information - with the PGM key at Off press and hold down the Feed button, while holding the Feed button turn the PGM key down to the PGM mode Release the Feed Button ----INI should appear or a group of 8 zeros If resetting does not work this indicates issue is repair level. PCRT470, PCRT480, PCRT48S, PCRT2100, PCRT220S This will erase all information - with the PGM key at Off press and hold down the Feed (journal) button, while holding the Feed button turn the PGM key down to the PGM mode Release the Feed Button ----INI should appear or a group of 8 zeros, now press one of the below 22500 Subtotal (PCRT40, 480, 48S) Or 23000 Subtotal (PCRT2100, 220S ) Wait for a receipt to print. If resetting does not work this indicates issue is repair level.
