Check your ground wires. Power and audio need to be ran on opposite sides of the vehicle. Try re grounding the radio the a new location. make sure all grounds are connected to bare metal.
Nick i believe that you have a simple ground loop problem. To fix that you'll need to run a ground wire from your EQ to the body of the car. (the shorter the wire,the better the ground)
Find the ground wire (black wire) coming out of your EQ. Splice a wire into that wire,and then connect that wire to the black wire coming out of your Head Unit,and that should solve your problem.
