SOURCE: I want to remove the 4gpm pump on my pressure washer.
HI, It sounds like it is just stuck on the keyway as these can be very tight. You need to force the pump of evenly on either side and should come of if patient.
Testimonial: "I'm sure the answer is correct. Over time my use of harsh chemicals no doubt corroded the key-way."
SOURCE: I bought a troybuilt pressure washer used and i
if you left it sit for a while & did not turn the fuel tap off,it may have flooded and therefore the oil level would have risen causing the oil to over flow.
always turn the fuel tap off when not using your pressure wahser.
