Motorola MC9190-GST Logo
A
Anonymous Posted on Jun 30, 2014
On a MC9190 how do I set the beam width from short range to long range?
Kelly
Level 2:
Habit-Forming:
New Friend:
  • Motorola Expert 60 Answers
  • Posted on May 04, 2016
Kelly
Motorola Expert
Level 2:
Habit-Forming:
New Friend:
Answers
60
Questions
0
Helped
75657
Points
287
These devices have several different scan engines and cannot be changed to do one or the other. The long range can scan at a close distance, however, short (standard) range cannot do both.
Tech Support Barcoding Technical Support
  • Official Brand Answer 3,100 Answers
  • Posted on Jul 22, 2014
Motorola Mobility
Level 0:
Answers
3100
Questions
Helped
685054
Points
13487
2answers
Why wont motorola mc9190 wont load
It is best to contact Motorola Solutions. Http://portal.motorolasolutions.com Mark Motorola Mobility Support
2answers
Mc9190 freezing disconnecting usb
Contact Motorola Solutions Get Support or Zebra Technologies Support Downloads
Mark
2answers
Motorola MC9190-G beam width setting
Hi
Mark
Mc9190 laser beam width is too wide. I need to change the width of the beam. How can I do this?
Hello
Support Downloads. They aren't helping on FixYa yet so it is best to reach out directly.
Mark
1helpful
User manual for DOD DFX9 DIGITAL DELAY GUITAR PEDAL
Can't find a manual but can still explain. Delays, chorus, flangers, and reverbs are all the same effect except the different names of them will allow you different adjustments. Chorus usually has a width control which controls pitch shifting. Flangers and delays will have a feedback control which simply means, how many times you hear the echo. On reverb units, room size means how long of echo(even though it;s short) you want. Delay is the same with much longer echo, feedback is the same as on flangers except the flangers time is very short meaning the effect is at almost the exact time resulting in feedback causing a metalic sound. I probaly just confused you but good digital delays usually have all the features and will usually do all 4 effects depending on how you set them. If you want delay, set width on 0 and adjust time and feedback. For flanging, adjust width and speed and feedback. Chorusing, adjust time, width, and speed. Reverb, adjust time, set width on 0, and feedback. I see it has a level(mixture, how much effect you hear), and a replay(feedback, how many times you hear it), and a delay knob,(how long the echo will be) The range/mode switch allows for settings of diferent time lengths and INF setting allows for infinite repeat. Hope this helps.
3helpful
2answers
MC9190 WLAN Problem
To permanently disable the Suspend Mode on a MC9190:
On your PC, create an empty text file, then type the 2 following lines:
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Power\Timeouts]
"BattSuspendTimeout" = dword:00000000
Save the file, then change the extension to ".reg". This changes the text file into a registry file.
Copy the registry file in the /Application folder of the scanner gun. Cold boot the device. Your MC9190 will no longer go to sleep mode, or "suspend mode".
To automatically enable the Wireless antenna at startup, create another registry file, then type the 2 following lines:
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\WLAN]
"InitialState"=dword:00000000
Save the file, and copy it into the /Application folder of the scanner gun. Cold boot the device.
1helpful
2answers
What was the year that the Slickcraft SS140 was built and what is the beam width?
this model was built in 1965 here is a link to the PDF artile about the history of the comapny if u are interested in reading it.
http://www.hope.edu/jointarchives/quarter/winter05.pdf
Not much info exists but the beam is stated in one article as 8'0"
Jul 20, 2010 • Boating
On a MC9060 how do I set the beam width from long range to short range?
If it is a Lorax equipped unit, you can't. The extended range scanner in the Lorax scanner version will read a 'standard" barocde, but from farther away than a standard range scanner. You just have to find the sweet spot. If you have further questions, contact the Motorola help desk at 1-800-653-5350
1helpful
Have some red shadowing in picture
Without seeing the set and checking it out, this is hard to accurately tell.
The following is when a single CRT or tube in a projection TV set starts to get weak. It is the same for a CRT when any one of its electron-guns starts to go weaker than the others.
On any CRT based set either with a single CRT or with seperate projection CRT's, as the tube(s) (CRT's) get weak their emission goes down. One of the symptoms is that the beam focus gets softer.
When a CRT goes weak the beam current will decrease. This lowers the mass or intensity of the electron beam. This makes the beam width wider, and thus the image focus is softer. Having a wider beam in a single CRT or single colour section of a CRT's electron gun also means that there will be more beam width overlap in comparison to the other CRT's or the other electron-guns in the case of a single CRT. This will give the appearance of an overlap or edging especialy with sharp or thin lines.
There is also a symptom where the convergence can get less accurate as the convergence control circuits age. This means that the scan tracking between each of the CRT's or the electron-guns in a single CRT start to not be able to accurately keep converged to each other. This will produce a border effect between the beam position accross the scanning of the screen.
Sometimes with a projection CRT set if there are separate focus controls in the high voltage (HV) section for each of the colours the beam focus may be able to be cheated if the CRT is not too weak. In most CRT sets the focus voltage is shared between all the colour channels, and thus there is no possiblity to control each channel individualy.
With weak CRT's there are other factors that come in to effect. One big one is that the colour tracking gets impossible to be accurate. This is because the gain liniarity of the tube becomes out of spec. As each of the CRT's or the electron-guns in a single tube become weak they will lose their tracking accuracy in relation to each other. In the design of the drive circuits of the better TV sets there are some auto circuits to try to make sure that the tracking is stable. But, when the electron-guns become too weak the circuits run out of range.
Jerry G.
Top Motorola Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
