Pride New Mobility Legend 4 Wheel Scooter Logo
A
Anonymous Posted on Jun 30, 2014
I have a new Pursuit xl with a loud howell from the transaxle
Stuart Nimmo
Level 2:
Habit-Forming:
New Friend:
  • Expert 88 Answers
  • Posted on Jun 02, 2016
Stuart Nimmo
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
88
Questions
Helped
20919
Points
101
This is very likely to be a binding hand brake, with a bit of help you can check this. IT IS NOT DIFFICULT BUT IF YOU DOUBT YOUR ABILITY GET A QUALIFIED MECHANIC TO DO THE FOLLOWING;
First loosen the rear right centre wheel nut ONLY and then carefully raise the back wheels off the ground and place blocks securely under the chassis frame.
Continue undoing the central wheel nut (only) and remove the rear right wheel and small axel key. With the scooter securely raised and all hands, clothing and obstructions out of harm's way switch on the scooter and use the wigwag to run the motor. With luck the noise will have gone, in which case it very probably was a binding brake pad, possibly caused by a dry, sticky cable or rusty or dry parts.
Try a spot of cable/ leaver lubrication (WD40), do NOT get grease or oil on the brake pads or on the wheel drum, clean these with a dry brush and rags. After lubrication work the hand brake leaver until it feels free and the lever returns fully.
Reassemble the right rear wheel onto the stub axel matching the groves exactly then tap the key back into the matching slot.
Test while the wheel is still off the ground, with luck the noise (which may also sound like cyclical scraping) will have gone.
NOTE! If you have any doubt about your ability to do this safely, have your brakes serviced - any good car or motorcycle mechanic would be able to thoroughly do this in about 30 minutes.
Manual for bell & howell 2143 xl 8mm film camera
The Bell & Howell 2143 XL manual is not available for free online. However, a few sites have reprints or original copies for sale. One source: http://www.oldtimercameras.com/manuals/camera-manual-Bell-and-Howell-2143-1075.asp . There is also a repair manual available. The instruction manual is under $15 plus $8 postage.
I hope this helps.
Jul 19, 2016 • Cameras
Why is my pride pursuit scooter dead... no lights anything
Sounds like the water has damaged the controller or the wiring.
It is a crying shame moter went out on my pursuit under warrant early july have not got replacement yet i know that there should be one in stock i am sure tha there are be produced as i speak
chase them up, and threaten legal action if it is not with you by the end of a week, they are legally responsible, use your rights or if your disability is to restrictive for that get a friend or if in UK trading standards to help.
Pride Pursuit XL scooter won't charge
Is this the Pride Colt XL 8 scooter ? if so look at the steering column, there is a fuse here for the charger ?
Please give feedback.
1helpful
Good morning i ha ve been given a Bell & Howell Folmosonic XL 1235. Could you please let me have some instructions for it. I am a complete novice and don't hav e a clue about how to operate...
Unfortunately, I don't seem to be able to locate a free manual for the 1235. However, I did locate a manual for the Filmosonic 1230 XL.
http://www.mondofoto.com/manuals/bell+howell+1230-filmosonic-xl/
It's a slightly different model but it might point you in the right direction.
DYSON HOWELS
Follow you guide and break it apart and make sure there are no blockages. Somtimes paper or cardboards will get stuck and makes a howling sound.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
