Make sure the drum is spinning. Also you may want to make sure the pump is not plugged.
Is the machine is spinning and draining check that the pump or outflow pipe is not blocked.
Try first to check the outlet pipe that goes into the sump under the sink or where ever you have the pipe going to. Get ready with a bucket or pan and disconnet the outflow pipe from the sump, drain the water into the bucket/pan then check for blockages. If the pipe is clear from blockages then two things will need to be checked. 1) the pump to see if it is blocked, 2) the carbon brushes to see if they have worn down. If they have your machine will not spin or move for that matter.
Good luck
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
i check it and my washer is not spinning
