Nortel Business Series Terminal T7208 - digital phone Logo
A
Anonymous Posted on Jun 30, 2014
NortelT7208 voicemail what are the steps for recording a new general greeting that the customer would reach in the event we are not able to answer?
2answers
How do I change the voice mail massage?
It varies by carrier, but most services walk you through options when you call voicemail. You want the personal options and greetings selections to change the message.
I need to change the greeting of Iphone 3. Where to go?
I'm assuming you mean the voicemail greeting message.
iPhone 3GS How to Change Your Voicemail Greeting GROK Knowledge Base
This article should help. Has step by step instructions on how to change your voicemail greeting on your iPhone 3.
How to Record Voicemail Greeting for Your iPhone
Here's another step by step guide.
Hope this helps!
How do I record a mailbox greeting on Avaya 1408?
Hi Tourmaster,
I have these steps for you on how to do it. Hope it helps.
Mailbox Greeting While the voicemail system will play a generic greeting to caller, prompting them to leave a message, you can record your own greeting.
1. Press the key%20messages.zoom50.png MESSAGES button. Depending on how your system is configured, you may be required to enter your voicemail password and then press the Done soft key. The visual voice menu is displayed.
2.Use the up and down arrow keys to scroll to the option Greeting.
2.Press the Select soft key or OK.
3. Use the soft keys to listen to and record your mailbox greeting.
• Listen
Listen to the current greeting or the new greeting just recorded.
• Record
Record a new greeting. Note that the greeting must be at least 3 seconds long or the voicemail system will discard it.
• More
Switch between the different sets of available soft key functions.
• Submit
Submit the new recording as your mailbox greeting.
• Delete
Delete your current mailbox greeting. The voicemail will use its default greeting.
Apr 28, 2014 • Avaya 1408
How do I set up voice mail on an iphone
Adding Voicemail for the First Time
  1. Tap the "Phone" button on your iPhone.
  2. Select "Voicemail." The iPhone will prompt you to create a password for accessing your voicemail, then will allow you to record your first greeting.
  3. Click "Save" to set your recording to your voicemail greeting
Recording a New Greeting
  3. Choose "Greeting > Custom."
  4. Select "Record" and begin recording your voicemail greeting.
  5. Hit "Save" to set your recording to your new voicemail greeting
3helpful
2answers
Setting up your voicemail
I bought and Uniden Dect 6.0 phone and the other day I had a voicemail msg but I can't retreive it how can I do that the book doesn't show how to set up for voicemail
Change voice mail message from one person to another person
Step 1 Lift the handset for your telephone and listen for the dial tone. Dial the access code you were given by Verizon when you signed up for residential telephone service. Dialing the access code will call the voicemail system. If you do not have an access code, you will need to call Verizon Customer Servicemag-glass_10x10.gif (see link in Resources).
  • Step 2 Identify the telephone number you are setting up voicemail services for. If you are calling from that telephone number, enter the temporary passcode and then press "#." The temporary passcode is the last 4 digits of your residential telephone number. If you are calling from a different phone, press "*" when the system greeting starts to play, then enter the 10-digit telephone number when prompted. After this, you will be asked to input the temporary passcode.
  • Step 3 Choose a new passcode. The passcode must be from 4 to 8 digits in length. It should be easy for you to remember, but difficult for others to guess. Do not use easy to guess numbers, such as 1234 or 1111. Also do not re-enter the same temporary passcode, since it will be easy for anyone to guess.
  • Step 4 Record your name. Simply say your name, without a long complicated message. This recording is used by the voicemail system to identify you whenever you forward a message to another user. It is not used as the standard greeting when a caller is directed to your voicemail to leave a message.
  • Step 5 Record or change your personal greeting. This greeting is played any time someone reaches your voicemail box. Record a friendly greeting to announce that you are unavailable and will return all calls upon your return.
    Decide if you want to set up a different mailbox for each family member. Verizon residential telephone service allows you to set up multiple mailboxes so that everyone can have his own private message center. Callers who reach voicemail will be prompted to press "1" to leave a message for one person, press "2" for the next person, and so on.
  • Step 6 Hang up the telephone. When you have finished setting up the voicemail system on your Verizon residential phone line, hang up the phone to end the call and exit the voicemail system.
  • 1helpful
    I tried to re-record a voicemail message from my office phone, but the voicemail box is on a different phone. I entered the system by placing the voicemail box ext that I wanted to update. I followed the...
    it must have been the main general mailbox you accessed, when in the voicemail the greeting number it will ask which prompts you to press * or # to re - record current msg. try intercom 777 and if no answer still reboot the system . power switch on upper right of the cabinet.
    3helpful
    How can i record a voicemail greeting
    I assume that you have voicemail on your plan, and your carrier or service provider supports it. First call your voicemail number and wait for the announcement as the whether or not you have any messages. Then next few steps may vary depending on your provider.Enter your password if asked, Voice will tell you you are in main menu, Select personal options number. Select personal greetings. Here you have a choice between extended absence, standard and personal. Select personal, record your greeting, and press # to keep your recorded message. These steps may vary depending on your carrier, but are generally pretty standard, if you simply follow the voice directions.
    Problem setting up voicemail
    Check the procedure is correct.
    1 Tap Voicemail, tap Greeting, then tap Custom.
    2 Tap Record when you’re ready to start.
    3 When you finish, tap Stop. To review, tap Play.
    To rerecord, repeat steps 2 and 3.
    4 Tap Save.
    Hope this helps
    Regards
    Voicemail reset
    Norstar Common Voicemail Features To Check Your Voicemail:
    1. Press the Check Voicemail key or press the Feature button, then 981
    2. Enter your password
    3. From here you can listen to messages, change your greeting, change your password, etc.
    To Leave a Message for Someone in Your Office:
    1. Press the Leave Message key or Feature 980
    2. Enter the mailbox number (extension number. of the person you want to leave a message for
    3. The display will show the name of the mailbox owner, press OK
    4. Leave message
    To Access Your Voicemail box from Another Phone:
    2. Press the OTHER softkey
    3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
    4. Press the OK softkey
    To Access Your Mailbox from Outside of the Office:
    1. Call the main office number or your DID (if applicable.
    2. If the call is answered by a receptionist, have them transfer you to your voicemail box
    3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
    4. At the prompt, enter your mailbox #(extension #. and password all together
    To Transfer Someone to a Voicemail Box:
    1. Press the Transfer to Voicemail key or press the Feature button, then 986
    2. Enter the mailbox # (extension#.
    3. The display will show: Call Transferred
    To Change Your Personal Greeting:
    3. Press the ADMIN softkey
    4. Press the GREET softkey
    5. Press the REC softkey
    6. Press the PRIME softkey
    7. Press the YES softkey
    8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
    To Record Your Alternate Greeting (Used when on vacation or out of the office.:
    5. Pres the REC softkey
    6. Press the ALT softkey
    8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
    9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
    10. Press the ChOOSE softkey
    11. Press ALT softkey
    12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
    13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
    took this from a guide i found, helped me out
    Top Nortel Computers & Internet Experts
    MrFixitSTTL
    MrTrekot
    MrTrekot
    Garatuss
    Garatuss
    Level 1 Expert
    Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
