SOURCE: how do I change name
From the phone connected to Jack 01 or the authorized phone (generally 101) press PROG and dial **1234 Dial 004 and ENTER and dial the ext number of the phone you want to change Use the keypad to enter the name (you have Upper and Lowercase letters) and the arrow key to step to the next character. When you finish, press STORE.
Carl
SOURCE: Hi I would like to
To what? There's a complete table in the Operations Manual (OM) or can you remember 0, 1 and 2? 0 assigns single lines....don't touch them. 1 plus ext assigns intercom numbers, and 2+access code and number is used to set personal speed dials (you also have 30 under the touch pad). Other commands set up Transfer to VM, VM record, CID display, Headset mode, etc. etc.
If you don't have a copy of the OM, here's one. Please rate this solution because as soon as you do, or after a short time, this manual will be gone. http://public.carl.airpost.net/misc/200_TDA_OM_10-11.pdf
Carl
SOURCE: I have a panasonic kx-dt333
When the auto attendant answers, press #6 then * and your extension. It will be just like you had diealed 165 or 500 from the phone on your desk. Unless, of course, you have a ESVM or non-TVx voice mail system.
Carl
