Oct 25, 2014 - In this video I'll be showing how to fix a washing machine with all the lights flashing and how to identify error codes or fault codes on Hotpoint, ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - Flashing lights Many modern washing machines display error codes if they detect a fault, but they don't all display a readable error code.
? 8:05
https://www.youtube.com/watch?v=P6WZNLO6wE4
Oct 22, 2014 - Uploaded by how-2-repair.com
Flashing Lights on Washing Machine How to Repair Hotpoint, Ariston, ... flashing like this.error faults are available at our website for all makes.
? 4:36
https://www.youtube.com/watch?v=S1L2N7srXKs
Mar 27, 2014 - Uploaded by DextersLab2013
Indesit Washing Machine Repair: Flickering Or Flashing Lights... Since making this video i have had to replace all of the remaining capacitors ...
It is possible your water supply is to low or your screens may be blocked at the inlet attachment to the washer. The other scenario a sticky or failing pump solenoid ; by which a direct replacement of the pump assembly may be required. Try to lubricate and actuate valve by hand if possible.
"Error 22" on a Pioneer usually means an unsupported CD format. The disc you are trying to play is not supported or is very badly scratched so the player cannot determine the format.
Error code E09 on a Hotpoint washing machine means software fault. This error is not easy to fix and you may need a professional help. You can find more information about Hotpoint error codes here: https://www.justfixed.co.uk/hotpoint-washing-machines-error-codes/
Enable the device. Since the most common reason you'll see a Code 22 error in Device Manager is because the device has been manually disabled, try manually enabling it.
Most of the time this will fix a Code 22 issue. Don't worry if it doesn't, however. All that means is that the Code 22 you're seeing was caused by something a bit less common.
There's always the chance that the error Code 22 you're seeing on a device was caused by a temporary problem with the hardware. If so, a restart of your computer might be all you need to fix the Code 22 error.
Did you install a device or make a change in Device Manager just before the Code 22 error appeared? If so, it's highly likely that the change you made caused the Code 22 error.
Undo the change if you can, restart your PC, and then check again for the Code 22 error.
Depending on the changes you made, some solutions might include:
Important: If a USB device is generating the Code 22 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
Note: Correctly reinstalling a driver, as in the instructions linked above, is not the same as simply updating a driver. A full driver reinstall involves completely removing the currently installed driver and then letting Windows install it over again from scratch.
Update the drivers for the device. It's also possible that installing the latest drivers for the device could correct the Code 22 error.
If updating the drivers does remove the Code 22 error, it means that the stored Windows drivers you reinstalled in the previous step were either damaged or were the wrong drivers.
Clear CMOS. If Windows had to disable the device, generating the Code 22 error due to a lack of system resources, clearing CMOS might fix the problem.
Update BIOS. Another possibility is that a newer BIOS version could better pass system resource handling to Windows, correcting the Code 22 error.
Move the device to a different expansion slot on the motherboard, assuming of course that the piece of hardware with the Code 22 error is an expansion card of some kind.
If the Code 22 error is due to a lack of system resources available for the card, moving it to a different slot on the motherboard could clear up the problem. This isn't as common a situation with newer hardware and Windows versions but it is possible and is an easy troubleshooting step to try.
Replace the hardware. A problem with the device itself might be the root cause of the Code 22 error, in which case replacing the hardware is the next logical step.
While not likely, another possibility is that the device is incompatible with your version of Windows. You can always check the Windows HCL to be sure.
Note: If you're positive that the hardware is working properly and is properly configured then you might consider a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either before you replace the hardware, but you may have to give them a try if you're out of other options.
Please let me know if you've fixed a Code 22 error in a way I haven't mentioned above. I'd like to keep this page as accurate as possible.
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more.
Be sure to let me know that the exact error you're receiving is the Code 22 error in Device Manager. Also, please let us know what steps you've already taken to try to fix the problem.
Show Full Article
