SOURCE: The display on my salter bathroom scales is
I held the two arrow and set buttons together for a few seconds and it cleared
SOURCE: setting the clock on salter scale model 5007
Hold down the g-oz key and the off key at the same time for about 5 sec's
The hour digit will flash
press the ml-floz key to move the hours.
then press the g-oz key again to move to the minutes.
press the ml-floz key again to set the minutes.
press the g-oz key and it moves to setting the cloak to 12h or 24h option.press the g-oz key to set the time.
And your done.
SOURCE: salter 1200 wall scales and
It is the internal problem with display unit.Just open the case check for loose connection to the display board.Clean the socket and place it tight again.If still the problem persist you have to replace the socket cable.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
SOURCE: Hi, My salter scales model
Did you ever find a solution? Mine are reading L also after a battery change. Thanks
