Maytag MSD2454G Side by Side Refrigerator Logo
A
Anonymous Posted on Jun 30, 2014
ICE MAKER DISPENSING CRUSHED ICE ONLY - Maytag MSD2454G Side by Side Refrigerator
5 Related Answers
l1tmorris
  • Posted on Feb 04, 2008
SOURCE: maytag side by side MSD2735GR
well sometimes it clogs up , when i open the frig door sometimes the ice falls out since the actual cup in inside of frig is full of the crushed ice.
Anonymous
  • 52 Answers
  • Posted on Mar 26, 2008
SOURCE: ice maker
There is something called a crusher control rod located on your icemaker bin. If you pull the bin out, you'll see it protruding from the backside of the bin. That rod inserts into the solenoid, which looks like a hole usually when looking in the freezer with the ice bin removed, it's toward the left side behind the bin.
This solenoid and rod work together to give you either crushed or cubed ice. See if the solenoid is stuck or iced up. You should be able to remove the ice and push it up and down to break it free.
Anonymous
  • 8619 Answers
  • Posted on Jan 24, 2009
SOURCE: Ice maker only makes cubes. It will not make crushed ice.
Hi
Kindly check it could be because of following reasons :
  • Freezer may not be cold enough.
    Temperature must be 5 degrees (Fahrenheit) or colder to work properly.
  • Normal ice making capacity.
    The ice maker will produce between 2.5 to 4.0 pounds of ice a day depending on your model. Side-by-side models come with a large ice bucket and it may take up to three days to fill this container.
  • Water supply valve may not be completely open.
    Open valve completely.
  • Water supply valve may be blocked by foreign material or may not be large enough.
    Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
  • Water filter may need changing.
    If equipped with a water filter, replace filter canister or cartridge.
    Please feel free to contact for further assistance
    Thanks
    Rylee
  • fordexpert
    • 5692 Answers
    • Posted on May 19, 2009
    SOURCE: want ice maker with crushed ice maytag
    Try looking in your phonebook for Servall. It is a reputable appliance parts source. Or if you can check online for the Maytag website you can usually find the part yourself and order it or talk to customer service. Last, there are a number of online appliance parts companies which may sell genericparts for your unit.
    Anonymous
    • 5 Answers
    • Posted on May 31, 2009
    SOURCE: Not dispensing ice cubes, only crushed
    Yup, do like I did. Clean the caddie of all ice cubes. Place a large water catching tray under the door, and run hot water from the inside where the the caddie holds the ice. You will see large chunks of ice that was freezing up your cube maker. After a couple of glasses of hot water pouring through the caddie, it will defrost and the frozen part will be released. Take off the caddie, and run water through it from your sink. Clearing all ice debris. Replace the caddie. Do not use for 24 hours, and it should run beautifully. Mine did that before it froze up and I cleaned it. You should probably take the caddie off every couple of months and run water through it to keep it clean of frozen debris, make sure its dried off well and put it back, wait overnight. and it should be ok.
    This is what I did, hope it helps.
    Samsung ice maker. Why has my ice maker stopped dispensing cubes? Have tried changing the selection on the door from cubed to crushed, but will not go back to cubed.
    you shud be able to reset the system , if not you can find the same model here or a newer model>>>www.discountbargainprices.com
    1helpful
    2answers
    Mu Kenmore refrigerator's ice maker is dispensing crushed iced even in the cube mode
    Take out the ice bucket and check the metal arm and make sure it moves freely. Ice may have gotten stuck.
    Ice not dispensing through the door and I dont hear a motor
    Ice Maker Not Dispensing Ice ' ThriftyFun
    www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
    Question: Kenmore Refrigerator Will Not Dispense Ice Through the Door. My Kenmore... I don't hear the motor or the crushed ice. What do I do? I have a nearly ...
    Ice maker is not dispensing - Checking auger motor & ice ...
    ? 5:33
    https://www.youtube.com/watch?v=Uk83V-fA8Pk
    Jul 1, 2013 - Uploaded by ApplianceVideo.com
    Ice maker is not dispensing - Checking auger motor & icebucket - Maytag, Whirlpool MSD2550VE502 ... Don't like this video? Sign in to ... The Geek - Maytag French Door IceMaker Replacement - Duration: 25:28.
    Ice Dispenser Repair Guide - Appliance Repair Guide
    www.appliance-repair-it.com/ice-dispenser.html
    Can I disable my crushed ice maker
    Good Morning Friend,
    You want to disable your crushed ice maker on your Frigidaire refrigerator, model# FRS26R4A. You will need to push the "Cube" button for the ice dispenser to stop dispensing crushed ice. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
    Ice maker only gives crushed ice, there is ice buildup
    clear ice and check. if not the relay board behind dispenser might be out
    6helpful
    2answers
    Ice maker not dispensing ice
    If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
    GHE monogram ice maker.
    pull the icemaker out, say be one inch, shack it a bit, and jam it back in. We've done that each time we had that problem, before it started to work. The icemaker is designed poorly, my openion, and gets jammed easily each time you use the crushed ice. crushed ice jams the ice crusher, and cloggs the pathway resulting a no ice dispensing situation. Also try using only whole ice cubes, instead of the crushed ice. the less you use the crusher the less you'll have to problem. one last thing. if the ice is sitting in the basket for a while, due to poor ice despensor opening door design, the ice in the basket cloggs together causing the probelm.
    2helpful
    My icemaker is not making ice. This has happened 3 times in the past 3 years but this is the longest it has gone without making ice. The other 2 times it lasted 2 days. It has now been 4 daysince the ice...
    Check the following:
     Is the freezer door closed completely?
     Is the ice storage bin installed correctly?
     Is there ice in the storage bin?
     Has the ice frozen in the storage bin?
     Is ice stuck in the delivery chute?
     Has the wrong ice been added to the storage bin? Use only
    cubes produced by the current ice maker.
     Has the ice melted around the auger (metal spiral) in the
    ice bucket?
    Dump the ice cubes and clean the ice storage
    bin.
     Is the ice dispenser stalling while dispensing “crushed”
    ice?
    Change the ice button from “crushed” to “cubed.” If
    cubed ice dispenses correctly, depress the button for
    “crushed” ice and begin dispensing again.
     Has the dispenser arm been held in too long? Ice will stop
    dispensing when the arm is held in too long. Wait 3 minutes
    for dispenser motor to reset before using again.
    Ice maker does not dispense cubes
    THE SOLENOID IN THE ON THE ICE MAKER MOTOR IS NOT WORKING IT HAS ICE BUILD UP ON IT OR IT HAS A SHORT IT PULLS THE PLUNGER THAT OPENS THE FLAP THAT LET ICE CUBES FALL OUT. REMOVE ICE MAKER AND THER ARE 2 5/16 SCREWS THAT HOLD PANEL IN THEN UN PLUG MOTOR AND USE HAIR DRYER & DEFROST MOTOR AND SOLENOID SHOULD WORK IF NOT MAY NEED TO REPLACE SOLENOID.
    Top Maytag Refrigerators Experts
    vince
    Johnny 1000
    Jesse Walters
    Jesse Walters
    Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
