Are you the only person connected to the machine can others? try different file pdf, web page, document email
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Konica Minolta bizhub C250
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
SOURCE: Konica Minolta Error code C-D351 on a Bizhub C250
Hi
I have come across this kind of problem.
Is your BizHub on the network? If yes, please switch it off completely, and take the Ethernet cable out of the BizHub.
Wait for atleast 30 seconds and reconnect the cable. Now start the printer again and see if the error message goes away.
Hope this helps!
SOURCE: how do you reset the life of the transfer unit on the Bizhub C250
Yes,
Remove Trasfert belt unit.
On the left handled remove one screw ( spring fixer) and remove right srew (over the belt / bar whit finger fixee).
Remove, on the left spring stoppage and metal handled.
Remove black little srew and take to hand fuse contact.
Change fuse (behind) with new identical fuse and reassembly.
It may be reset trasfert belt counter.
Sorry for my not good english.
Bye.
SOURCE: A blue line , 2mm, appearing at bottom of page.
Hi Info39684,
It sounds like your Cyan imaging unit has gone down.
Have you thought of changing the orientation of your paper from A4 protrait to A4 landscape. If the blue line is at the bottom, changing the orientation should hide the problem. It's not going to fix it, and if you use A3 then you will see the line again. It's just an idea and you could save yourself £250 on a new unit.
Regards
Taminol
SOURCE: Colour printing
Hi Alan,
Please ensure that the printer driver is set correctly.
Go to your Printer & Faxes menu, right click the C250, click printing preferences, click the Quality tab and make sure Colour is selected. Apply the changes and bingo!
The above assumes you are using Windows and a PCL driver.
Hope it helps
Regards
Taminol
