RTO 200cc Full Size Four Wheeler ATV Logo
w
william hobbs Posted on Jun 30, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bmx mini atv inition problems
The ignition came apart while riding. I put it back togather. Now when I turn key, brake lights work but no head lights and no start. any ideas? thanks
Brian Crowe
Level 2:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 78 Answers
  • Posted on Dec 10, 2014
Brian Crowe
Expert
Level 2:
Night Owl:
Answers
78
Questions
Helped
56278
Points
135
if you have a 4 wire ignition then you connected the wrong wires together. Connect the red and black together, that should get your lights and start button working and leave the other two wires seperated, they are to kill the spark. So when you want to shut it down just hold the other two wires together till the engine stops then seperate them again so it will start next time you want it to.
Bjg Junior
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on Jul 12, 2014
Bjg Junior
Contributor
Level 1:
New Friend:
Answers
15
Questions
0
Helped
3324
Points
34
If u mean ignition barel u put it toghether wrong,it is tricky,also can burn wiringand fuses
Steve P
Level 3:
  • RTO Master 3,912 Answers
  • Posted on Jul 01, 2014
Steve P
RTO Master
Level 3:
Answers
3912
Questions
5
Helped
1306966
Points
15904
What ignition are you talking about, the system that fires the spark plug or the key ignition? If its the key switch, you have put it back together wrong or it broke internally and you need a new switch. If this doesn't help. Find a professional.
KoKo Lamoco
Level 3:
Loyalty:
Visited the website for 30 consecutive days.
  • Master 374 Answers
KoKo Lamoco
Master
Level 3:
Loyalty:
Answers
374
Questions
0
Helped
104373
Points
1238
Modual probably gone
2answers
BMX 200cc ATV wiring diagram please.
It is Chinese, so you only get generic answers. The same unit has lots of names.
https://www.google.com/search?q=Bamx+200cc+wiring+diagram
Apr 16, 2022 • ATVs
When i turn my key off its stays running it dies when i turn head lights on . 2005 polaris sportsman 500 4x4 four wheeler
It sounds as though your ignition switch is not hooked up correctly. Follow the harness from the ignition switch to the bullet connectors under the front body plastic. Make sure the colors all match up.
Oct 07, 2019 • ATVs
My 2010 Polaris Ranger 400 has no power.
My Polaris 500 started quitting on me. It turned out to be corrosion on the left handle bar kill switch wiring. After repairing, I pulled apart many wiring connectors and filled them with dielectric (does not conduct electricity) grease to make them resistant to water and corrosion.
Sep 17, 2017 • Polaris ATV
2015 Sportsman 570 EFI won't start and will backfire after a couple of turns
does it have more than a one year warranty
strange
small back fire on an EFI system...
low km
disconnect battery terminals = reset factory default
try start again
check valve adjustment
Oct 27, 2016 • Polaris ATV
Why did lights go dim and battery died?
Search Results
    Battery Dead, runs but headlights dim - Polaris ATV Forum
    www.polarisatvforums.com > ... > Polaris Phoenix
    Jul 23, 2011 - Go Back · Polaris ATV Forum > Polaris Model Specific Discussions > Polaris Phoenix ... Two days later the battery was dead. ... run ok, but the lights weredim and they did not brighten with I rev'ed it up. ... Polaris ATV Legend. Polaris 2500 winch draining battery
    Jan 9, 2014
    No Electrical Power when Key is turned. New Battery
    Dec 18, 2013
    elctrical nightmare!!!
    Feb 19, 2011
    Slowly Losing Power Only when hot...
    Oct 13, 2010
    More results from www.polarisatvforums.com
    Headlights dimming - ATVConnection.com ATV Enthusiast Community
    atvconnection.com/forums/polaris/326484-headlights-dimming.html
    Apr 25, 2010 - The lights on my 99 Sportsman 500 go from bright to dim all the time and I ... did you check the voltage yet when they do thid to make sure it's still putting out ... The Rectifier is my guess, I rode my ATV with a dead battery for a ... Battery Help
    Sep 6, 2014
    dim lights at idle - Page 3
    Dec 6, 2012
    2001 400 4x4 (manual) electrical problem(voltage)
    Aug 17, 2005
    Rancher Ignition Problems
    Dec 10, 2003
    More results from atvconnection.com
    charging issues - Honda ATV Forum
    www.hondaatvforums.net > ... > Honda TRX
Feb 03, 2016 • ATVs
Bmx 4 wheeler
the rear wheel is the adjustment. loosen the main axle bolt and slide the wheel back until chain is tighter. if it has rear suspension there should be a small amount of slack in the chain when done. retighten axle bolt.
Sep 06, 2013 • ATVs
Top RTO ATVs Experts
Jay Finke
Jay Finke
Renee Knafel-Bullock
Jonathan Buck
Jonathan Buck
Are you a RTO ATV Expert? Answer questions, earn points and help others
