Apple iPod MA446LL/A MP3 Player Logo
A
Anonymous Posted on Jun 30, 2014
Apple ipod touch instructions
WON'T CONNECT TO THE INTERNET
Mister Danger
Level 3:
  • Apple Master 5,631 Answers
  • Posted on May 07, 2015
Mister Danger
Apple Master
Level 3:
Answers
5631
Questions
0
Helped
1197665
Points
47629
Should connect through setting. Input wifi code or just indicate your connection if at hotspot.
5 Related Answers
Anonymous
  • 47 Answers
  • Posted on Mar 19, 2008
SOURCE: instructions for apple ipod 160GB operations
Apple Classic Manual
seaniepie
Sean Cole
  • 255 Answers
  • Posted on Jan 01, 2009
SOURCE: unable to connect my ipod touch to tv
I use both the composite and component cables from Apple with no problems. Go to the ipod settings, under video then tvout. Make sure it is set to your tv standard (NTSC or PAL) and the format (Widescreen or standard).
Also, make sure you are putting the video cable into the correct socket for it on your tv, either composite or component.
All the best
Sean
Anonymous
  • 59 Answers
  • Posted on May 15, 2009
SOURCE: i can't open my yahoo messenger from my apple ipod touch
try to get a free app from the app store and install it the may solve ur problem
Anonymous
  • Posted on Nov 03, 2009
SOURCE: Invalid Argument error in iTunes and App Store of iPod Touch 3.1
Do the following... On your Touch go to Settings -> General -> Reset -> Reset Network Settings..... When it starts again got to Settings -> About and check to see if your Wi-Fi Address has been Reset. Hope that helps
Anonymous
  • 9 Answers
  • Posted on Jun 19, 2010
SOURCE: MY APPLE IPOD TOUCH OF 8G & IT SAYS IPOD IS
If the solution above doesn't work, try restoring your iPod. Firstly, make sure you have the same (or above) version of firmware on your computer somewhere. By doing the next step, you need to know that all data and settings will be erased from your device. If you are OK with this, put your iTouch into DFU mode by:
1. Plugging your device into your computer.
2. Holding down the power button for 3 seconds.
3. Without releasing the power button, hold down the home button for 10 seconds.
4. Release the power button, but keep holding the home button for 30 seconds.
Next, go to the iPod Touch panel in iTunes, and click on the "Restore" button. Now follow the on-screen prompts.
If you want to restore your firmware to a specific firmware (advanced users), shift-click the "Restore" button and select an ISPW firmware file to update it to.
1helpful
2answers
IPOD TOUCH WONT TURN ON
Marclla, Check the attached links,instruction and guides to get IPOD up and running, Good luck.
I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info.
My iPod Touch 5th generation won turn on
If your iPhone iPad or iPod touch doesn respond or won turn on
Fix iPod won turn on problem Quick Fix
http://ccm.net/forum/affich-786664-5th-generation-ipod-won-t-turn-on
tip
Ipod not charging when i connect it to the usb port. or iphone.
If an alert says that your accessory isn't supported or certified. These alerts can appear for a few reasons: Your iOS device might have a dirty or damaged charging port, your charging accessory is defective, damaged, or non Apple-certified, or your USB charger isn't designed to charge devices
If your iPhone iPad or iPod touch won charge
How to Fix an iPad iPhone or iPod Touch That Won Charge Anymore
Help My iPad Won Charge
Help My iPod Battery Won Charge
ipod do not charging when connect it to the usb port Google Search
on Dec 06, 2017 • Computers & Internet
tip
How to Connect my Apple iPod Touch 8 GB to Internet
<p>Apple iPod touch is a touch screen version of its popular iPod device, similar in appearance and function of the iPhone. Like the iPhone, iPod touch is able to access the Internet, although by different means. While the iPhone usually connect to the Internet via a wireless network operator's mobile data, the only way to connect to the Internet in an 8 GB iPod Touch is the device to use built-in wireless adapter. <br /> <p><br /> <p>1. Get references to a wireless network nearby, if you are not home or do not have access to a public network without a password. If you're in a cafe, for example, ask the cashier to use the network password and you should use to connect. <br /> <p><br /> <p>2. Tap your iPod Touch "Settings" icon and "Wi-Fi." If a blue button "off" appears next to the Wi-Fi, tap it on the wireless adapter to connect the device. <br /> <p><br /> <p>3. Scroll through the list of wireless networks will appear, and then tap corresponding to your network. Enter a password - if the network requires - and tap "Connect" to your connection to the Internet iPod touch 8 GB. <br />
on Aug 05, 2011 • Apple iPod touch
How to restore
You can use iTunes to restore iPod Touch software.
Apple recommends using the latest version of iTunes to complete this process.
Follow these steps to get the latest version of iTunes and restore your iPod Touch software.
Back up your iPod Touch's data to your computer before the restore to prevent losing data.
You'll need to reinstall it after the restore process.
Connect to the Internet and install the latest version of iTunes from the Apple website.
Make sure your iPod Touch is connected to your computer.
Pick "iPod Touch" in the Source pane of the iTunes program.
Click on the Summary tab.
Choose "Check for Update."
Select "Restore" and follow the instructions to finish restoring your iPod Touch.
1helpful
Need guidance/instructions for connecting to Wi-Fi network
go here and read around... you'll find complete manuals, how-to, specifications and many more..
http://www.apple.com/support/ipodtouch/
1helpful
My iPod touch went all white then after I reset it the screen just went black and wont turn on now. Please help me!
  1. Back up your iPod Touch's data to your computer before the restore to prevent losing data. You'll need to reinstall it after the restore process.
  2. Connect to the internet and install the latest version of iTunes from the Apple website.
  3. Make sure your iPod Touch is connected to your computer.
  4. Pick "iPod Touch" in the Source pane of the iTunes program.
  5. Click on the Summary tab.
  6. Choose "Check for Update."
  7. Select "Restore" and follow the instructions to finish restoring your iPod Touch.
  8. Complete an Advanced Restore
  9. If following the steps in the previous section did not work, follow these steps to perform an advanced restore. Turn off the power on the iPod Touch.
  10. Plug the iPod Touch into your computer.
  11. Power on the iPod Touch.
  12. Press the "Home" and "Sleep/Wake" buttons together for 5 seconds until the Apple logo appears.
  13. Release the "Sleep/Wake" button but continue holding down the "Home" button. The iPod Touch should reboot, and iTunes will notice the iPod Touch in recovery mode.
  14. Return to the above section and follow those steps to restore your iPod Touch.
1helpful
My apple Ipod Touch is fully charged but will not display any of my music I downloded Screen stays blank, shows no data or anything cnnot get it to sync either
    Complete a Regular Restore
  2. Connect to the Internet and install the latest version of iTunes from the Apple website.
  7. Select "Restore" and follow the instructions to finish restoring your iPod Touch. Complete an Advanced Restore
  8. If following the steps in the previous section did not work, follow these steps to perform an advanced restore. Turn off the power on the iPod Touch.
  9. Plug the iPod Touch into your computer.
  10. Power on the iPod Touch.
  11. Press the "Home" and "Sleep/Wake" buttons together for 5 seconds until the Apple logo appears.
  12. Release the "Sleep/Wake" button but continue holding down the "Home" button. The iPod Touch should reboot, and iTunes will notice the iPod Touch in recovery mode.
  13. Return to the above section and follow those steps to restore your iPod Touch.
1helpful
Forgot passcode
If you forgot your iPod Touch password the only solution is to wipe and restore your last backup.
Apple Knowledge Base Regarding lost passwords
Instructions from Apple Support Document (Page 110)
Restore iPod touch from a backup:
  1. Connect iPod touch to the computer you normally sync with.
  2. In iTunes, select iPod touch in the sidebar and click the Summary tab.
  3. Click Restore to reinstall the iPod touch software, restore its default settings, and delete data stored on iPod touch. In iTunes, you can also restore from a backup without deleting data stored on iPod touch.
3helpful
5answers
Ipod touch - wireless connect to my MSI RG54g2 router
Hi and welcome to FixYa,
Initially, to your queries:
  • instruction book - pls click here;
  • passwords - open a browser, the MSI RG54G2 web interface is 192.168.1.254, password is "admin", less the quotes;
  • iPod touch - will auto detect your MSI
  • setting on my router - if allows your computer(s) to access the Internet, no further settings required;
  • iPod can connect to the internet - if no WEP or WPA is set on the MSI router.
This is of course assuming that the MSI RG54G2 is allowing your computers to access the Internet lready and will be shared to the iPod Touch.
Good luck and Thank you for using FixYa. Happy Holidays.
5answers
IPod Touch WiFi issue
  1. Tap Settings > Wi-Fi Networks, then pick the network.
  2. In the DHCP panel, select the Renew Lease button.
  1. Make sure you have an Internet connection and have installed iTunes 7.4 or later from www.apple.com/itunes. Apple recommends using the latest version of iTunes.
  2. Connect iPhone or iPod touch to your computer.
  3. In iTunes, select iPhone or iPod touch in the Source pane and click the Summary tab.
  4. Click "Check for Update." iTunes will tell you if there's a newer version of the iPhone or iPod touch software available.
  5. Click Update to install the latest version of the software. Or click Restore to restore iPhone or iPod touch to its original settings (this erases all data on iPhone or iPod touch). Follow the onscreen instructions to complete the restore process.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
