My unit will not work and does not show correct depth, etc. It works in simulator but not in normal. All I get is a display with a depth and bottom contour that is not actual. I changed transducers (to a new one)and there is no change. I reset defaults, no change. Is there a software fix for this? Humminbird no longer supports this product.
SOURCE: HAVE A HUMMINBIRD MATRIX-97 ,CARD
in 99% this problem arises because of firmware corruption.... or rest 1% hardware failure... so update firmware of your gadget ...
Hope this has helped you...
Thanks..
SOURCE: I have my Humminbird fishfinder
I would contact our customer service group and they will be able to help you. Our number is 800-633-1468.
SOURCE: I have a humminbird pmax 170. It does not show
Contact our customer service group and they will be able to help you. There number is 800-633-1468.
SOURCE: I have a humminbird 190c.
Hi, if it worked on another boat, either the new transducer is faulty or you may have bent a pin in the back of the sounder when you reinstalled it in your boat. Check the pins, if it still won't work retry in the other boat. If ok return your new transducer for replacement. Hope this helps regards Phil.
