Question about Casio fx-300ES Calculator
How do I get decimal answers
My Casio fx-300ES calculator's output is in fraction form. How do I change the setting so that it gives me a normal decimal output without having to push the "eng" button
  • 2 more comments
  • Anonymous Mar 26, 2014
    It used to give me only fraction answers, now I get decimals but I cant use my power buttons. Please tell me how to switch it back
  • Jett99
    Jett99 Feb 22, 2017
    good good To accredit Surface for playback of iTunes content: itunes for windows we have a look at the first machine with its iTunes Library nice.
  • ayesha65
    ayesha65 Apr 09, 2017
    It's a good piece of information. High intensity content and it is presented in a good manner. Hopefully waiting for your next post.
    uswalmartone |
    walmartone com login
  • Jeremiah64
    Jeremiah64 Jul 03, 2017
    Also added to this post is a great extra bonus https://tutuappguide.com apk data on your Android gadget. By utilizing the file.
I had the same problem. To change the output to decimals, do the following:
Go to Math mode, then SHIFT, MODE (set-up), 2 (lineIO). This will cause answers to show in decimal format. I hope this helps.
I was able to find a manual at: http://www.generalmanual.com/Calculators/Casio-FX-300ES-Scientific-Financial-Calculator.htm
Posted on Jan 25, 2008
Here is the problem solution I have a Casio fx-300ES:
chezbrgrnparadz@aol.com
Posted on Apr 29, 2008
This is a very good interrogative page with such awesomes answers. If you are a free roblox user then must try roblox hack to enjoy roblox free for lifetime. Online Roblox Free Robux Generator
Posted on May 16, 2018
2 Suggested Answers
SOURCE:
  • 8081 Answers
SOURCE: my new casio fx-300ES calculator
To change a displayed result into a fraction, press the [S=D] key.
To force a result to be displayed as a decimal number before it is displayed, press [SHIF][=] instead of [=].
Posted on Aug 16, 2011
I WANT MY ANS IN FRACTIONS NOT DECMIALS
Set the Input Output Display mode to MathIO. In thsi mode answers are given in fraction-radical forms whenever possible. To toggle between Fraction/radical and decimal, press the S<=>D key.
To access the above screen press [SHIFT][MODE](SetUp).
Jan 20, 2014 | Casio fx-300ES Calculator
Decimal mode casio
Your problem is not with the scientific display, rather it is with decimal representation (approximate) or fraction/radical (exact). representation.
If your results are in fraction/radical form press the [S<>D] key to switch from one to the other.
The calculator is by default in the MATHIO t output mode: results are in fraction/radical form.
If you don't like to work with this mode just change the IO mode to LineIO. To do so, press [SHIFT][Mode](Setup) and selct 2:LineIO
Oct 07, 2013 | Casio fx-300ES Calculator
How do you change decimal to fraction on a CASIO fx-300ES PLUS
To convert a single value between the symbolic and decimal formats, press the S--D key (above the DEL key). To have all results come out in symbolic form press SHIFT [MODE] 1 to select the MthIO mode.
Be aware that the calculator cannot display all values in symbolic form.
Mar 30, 2013 | Casio fx-300ES Calculator
I have a casio fx-300ES calculator. It gives all answers as improper fractions. How do I make it give decimal answers?
Hi suebie50
Have a great day.
To change the output to decimal form, you can do the following:
The answer will show in decimal format.
You can also use this website whenever you have further questions in using you calculator:
Hope it helps.
Thank you for using fixya.
Sep 14, 2011 | Office Equipment & Supplies
My new casio fx-300ES calculator outputs answers as a fraction... how can i change the output to a decimal point?
Aug 15, 2011 | Casio fx-300ES Calculator
I have a Casio fx-300ES calculator and everytime i push in a math problem it comes out as decimal form or fraction form. I don;t exactly know whats wrong with it, but it never gives me the right answer to...
I understand your frustration, but believe me there is nothing wrong with your calculator. You just have to invest a minimum amount of time to familiarize yourself with its powerful capabilities.
No matter. Your calculator has to input output modes. MathIO and LineIO. MthIO is new and it allows you to enter expressions as if you were doing it by hand (like in textbooks). LineIO is the old way.
In MthIO your displayed results are fractions or radicals (roots) or a mixture of the two. BUT if the screen cannot fit the fraction or radical form, the calculator will use decimal to display the result.
In LineIO you only have decimals results.
To get fraction or radical results configure the calculator to use MthIO. In this mode, if you want a result converted to decimal, just press the SD key. It will toggle between the two.
To set MthIO, press [SHIFT][MODE] and select [1:MthIO]
To set LineIO, press [SHIFT][MODE] and select [2:LineIO]
Dec 02, 2010 | Casio fx-300ES Calculator
When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Nov 07, 2008 | Casio fx-300ES Calculator
Casio fx-300ES Calculator Logo
37,215 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
