Why is my tv stuck at one volume level, what can i do?
Thank you, I will try that.
Are you using a remote control or the switches on the TV?
If using a remote;
First turn the TV off at the power point then wait for 10 seconds.
Then turn the TV back on
Then attempt top adjust the volume using the manual settings on the side or bottom of your TV, if that works then you may have a remote that either needs new batteries or does not work.?
Can you turn the TV on and Off with the remote control?
Can you change channels with the remote control?
If you can do both the above it would appear that the remote is working OK.
Does this fix the problem?
