Question about La Crosse Technology Wireless Temperature Station 9013
After changing the batteries how do i reset the time,date temp./?
How do I reset time and date on SioScan Atomic Clock? I need Arizona time zone - i.e. no daylight savings time
Put it into settings and then adjust time/date. It's not related in any way to temperature.
Apr 24, 2015 | Home
I couldn't figure out how to amend my last question, so here is one more piece of information. I just put batteries back in and reset the time/date. The Temp Up and Temp Down buttons WORK FINE
your thermostat may be locked go to honeywell web site punch in thermostat model # and look for set up pushing two button at the same time gets you in but you will need instuctions for set up
If you need further help, I’m available over the phone at https://www.6ya.com/expert/mike_9693b5ad75773352
Jan 31, 2015 | Honeywell RTH230B 5-2 Day Programmable...
How do I set my sharp atomic clock. Put in new batteries and set time and date on back of clock but the outside temp is not registering?
That makes scence, you have to have an outside temperature probe. If it is wireless it also needs batteries. Check manual for more details.
Nov 07, 2014 | Sharp Atomic Dual Alarm Clock Spc315...
Advent 5431 date keeps changing back to 2008
IS your TimeZone is Correct?
Right click on your clock, choose Adjust Date/Time.
Click Time Zone Tab. Make sure your Time zone is correctly set.
Boot into the BIOS (setup) screens and check the date and time there. If the date is off by years then that verifies you need a new CMOS battery. Do not confuse the CMOS battery with the large external battery you run the computer with.
Jul 25, 2012 | Advent Netbook
After battery change on my 2001 avalon the time/date reset to default even I set the time/date correctly then turn off the ignition and turn back on again then the time/date reset to default again .
If some connections were changed then the ALWAYS ON +12 volt to the clock circuit back up is not powered all the time . check if while the battery was changed if there was any link that was disconnected that is the continuous supply to the clock.
Jul 02, 2011 | 2001 Toyota Avalon
Skyscan atomic wall clock 87315. Changed battery
Press and hold the set key until time zone appears, then + or - to your zone.
Jan 31, 2010 | SkyScan Audio Players & Recorders
PC HARDWARE
Change the mother board battery it is flat when you change battery you will have to reset BIOS to your time and date
. Also your CPU and memory settings may have to be reset as well
Nov 01, 2008 | Intel Motherboard
Samsung S630 date gets reset while changing the batteries
It is really NORMAL that the date will be reset to the Manufacturer's date whenever you are changing batteries.
For you not to keep on changing the date and time of your camera, use Rechargeable batteries for a longer battery life span but make sure that you will be setting the battery type of your camera for the Rechargeable ones.
To set the correct battery type.
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see BATTERY TYPE
- Select ALKALINE if you're using NON-RECHARGEABLE
- Select Ni-MH if you're using RECHARGEABLE
- Press on OK/MENU button for changes to be saved
Turn off camera after the settings
have been changed to refresh the camera.
Dec 23, 2007 | Samsung Digimax S630 Digital Camera
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
When the batteries die I have to reset the date and time again in order to take pics! Was there something that I missed or did wrong?!
The manual states that when you change the batteries, you will have to reset the date and time; this is normal operation for this camera (though it is a pain!!!)
Sep 13, 2005 | Epson PhotoPC 850Z Digital Camera
La Crosse Technology Wireless Temperature Station 9013 Logo
66 people viewed this question
Top La Crosse Technology Measuring Tools & Sensors Experts
ka4iup
ka4iup
Are you a La Crosse Technology Measuring Tool and Sensor Expert? Answer questions, earn points and help others
