Uniden BC350C Base Scanner Logo
A
Anonymous Posted on Jun 30, 2014
How unlock Pr 9 - Loc - Uniden BC350C Base Scanner
I tried to press bake which turns the oven on usually and got LOC in white letters instead of a temperature
Perhaps indicating the oven door is locked.
Look for an unlock button.
my Fridgaire oven has a led to indicate door lock
Nov 13, 2016 • Ovens
Reset billb m000
HOW TO RESET UNIDEN 350c
PROGRAM BOTTOM DON'T WORK IT SHOW CHN +Pr 9 - loc WWHAT WOULD BE THE PROBLEM
Free radio unlock codes
Go to this link and try the solution listed there: http://www.ehow.com/how_5574057_gm-codes-display-says-loc.html
1helpful
Take GE Profile Oven LOC from pannel
the control board is bad,replace it there is no sequence to rectify this problem the board is bad
Jun 17, 2012 • GE Ovens
2helpful
2answers
I have a GE profile and it is reading LOC. can you tell me how to unlock it?
Hello & Welcome to FixYa
Press and hold 0 & 9 buttons for 20 seconds to unlock the control. Please get back to me if you have any other questions.
Kevin
1helpful
Do you have an instruction manual for the Chattanooga Delux pedal exerciser
Try this URL: http://www.chattgroup.com/product.asp?pr=508&ln=1&cn=5&loc=1 . The User's Manual (PDF) is on the right side of the page under Product Downloads.
I hope this helps.
4helpful
My ge profile range will not operate loc appears when you try to put it on bake
Hold the 9 & 0 down together till the loc on goes to loc off. About 5 secs.
Amana Oven Door won't open. Latch to lock it is broken.
After pressing Self Clean, Adjusting the Time and Pressing Start, the self cleaning cycle shows the # F57_ on the read-out. I tried to cancel and now the door opens, but I can't get the Bake to begin when I press Start. No matter what I press LOC flashes on and off, but the door is unlocked and the heat is off.
Please help!
Susan, PR
3helpful
Lock feature
LOC on is a lock out feature to prevent kids from playing with the stove. press 9 and 0 for 3 seconds and the loc will go off.
2helpful
Lighting the oven
Control Lockout (on some models)
Your control will allow you to lock out the
touch pads so they cannot be activated when
touched or cleaning the glass panel.
To lock the controls:
Touch the 9 and 0 touch pads at the
same time for 3 seconds until the
control beeps twice. The display will
show LOC continuously and the time
of day if not blacked out.
NOTE: All cooking and timing functions will be
cancelled when locking out the control.
To unlock the control, touch the
9 and 0 touch pads at the same time
for 3 seconds until the control beeps
twice, and LOC will be removed from
the display.
NOTE: Some models have a Control Lockout
pad. Touch and hold it for 3 seconds to
lock/unlock.
Gas/Control Lockout (on some models)
surface burners, oven burners and control
panel so they cannot be activated.
To lock/unlock the controls:
Turn all surface burners off.
Touch and hold the Gas/Control
Lockout pad for 3 seconds until the
display shows LOC ON.
To unlock the control, touch and hold the
Gas/Control Lockout pad for 3 seconds
until the display shows LOC OFF.
When this feature is on and the touch pads
are touched, the control will beep and the
display will show LOC ON.
 The control lockout mode affects all
controls. No controls will work when this
feature is activated.
 The adjustment will be retained in memory
after a power failure.
Top Uniden Radio Communications Experts
John
John
eradiostore
eradiostore
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
