Motorola Mobility RAZR V3xx Cellular Phone Logo
R
Rita Wroten Posted on Jun 30, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Was working. changed battery now dead.
Battery works in other phone. fully charged. phone acts totally dead.
  • Official Brand Answer 1,623 Answers
  • Posted on Jul 08, 2014
Motorola Mobility
Level 0:
Answers
1623
Questions
0
Helped
350710
Points
5677
Hi in this case I would suggest you to contact us: Motorola Support Find Answers Motorola Mobility Inc so that we can find a better solution for your issue.
Best Regards!
5 Related Answers
Anonymous
  • 30 Answers
  • Posted on Jan 06, 2008
SOURCE: Razr v3 dead battery
you have a dead battery, this happens often. all you can do is just buy one, ebay
Anonymous
  • 7752 Answers
  • Posted on Feb 23, 2008
SOURCE: Motorola RAZR V3
the mainboard is gone and have to either be replaced or taken to a mobile service center close to you and hvae them use special equipment to revive it.
Anonymous
  • 11 Answers
  • Posted on Mar 02, 2008
SOURCE: NTO ABLE TO CHARGE BATTERY
Try charging the battery for a long time.
Anonymous
  • 7752 Answers
  • Posted on Apr 15, 2008
SOURCE: Dead phone but keypad flashes
replace the LCD + flexcable on the phone.
Anonymous
  • 19 Answers
  • Posted on Sep 20, 2008
SOURCE: Battery will not fully or will not charge
Whenever you first purchase a device you must charge the phone fully otherwise if you charge it partially an then use it it will never charge good. You may need new battery see if youe warranty covers it \. If you are within 30 days of purchase you can exchange it at no cost!
Canon camera is 5 years old. Eventhough battery is fully charged, the display continues to say ..CHARGE BATTERY..... now camera is totally dead .... and no display text telling you to charge batteries
Try this trick. Pull battery and put camera in a zip lock bag and into freezer overnight. Take out and install charged battery and see if there is any change. This worked with a Go-pro I had, unbelievable! Capacitors get old and dry out and these sometimes affect the charge circuit as well as batteries getting old too. Li-po batteries (yours) get old if you use them or not so it may just be an expired battery.
1helpful
Xpera arc totally dead after charging
mostly it seems like a software problem. Did you try restarting it by pressing VOLUME DOWN + POWER button??
if it's not working , then take it to a service center and re-flash the software once.
Iphone won't start up
Un plug the battery check the connections on the battery and the iphone clean with some stochbrite and wipe off with 90% alcohol let dry and should work fine as long as the battery is fully charged.
Phone will not turn on and is as good as dead. It has not been damaged in any way, the battery is fully charged. It was working fine yesterday
no.the battery its not fully charged
the battery got dead.yo need to relife it.by sending it to a mobile repaire store.
or buy a new battery
May 08, 2011 • Cell Phones
2helpful
The phone has been dead for more than a year
You cannot usually charge a totally flat battery from the USB port. These are only used to "Top UP" the battery... You need to replace it with a fully charged one,and then us the USB to keep it fully charged.
1helpful
3answers
Bought my phone yesterday...Battery was losing charge quickly.. battery was down to half charge after about 15 minutes of fully charging.. Was trying to let the phone die completley then fully charge it,...
Ok first of all you should never let a phone die out of charge at all.IF it dies out of charge there are chances it might charge again once you charge it but in some cases it wont, you need to boost your battery just like jump start your car.It cannot be done anywhere except some service centre. If you are not taking to your service center , then you need to buy a new battery.
Oct 08, 2009 • Cell Phones
Battery fully charged but cannot use camera. Applied new batteries works in review mode only Fuji Fine Piix F420
My camera had a similar problem. It would work only in review mode and as soon as photo/film mode was selected it went dead. What I did was 'discharge' the battery totally and then fully recharged it. This can be done by going to Menu-Option-Setup-Discharge. After I had done this the camera stopped going dead but the battery still had a very poor lifespan. I bought a new battery and now the camera works as new. Hope this helps-Steve.
The phone does not charge/ does not hold the charge.
Check if the battery is working well, first, discharge it al, then charge it fully and use the phone, if the battery appears to be charged and after a call or something, it says "LOW BATERY", you have to change the battery. Now, i the phone isn't charging, it is necessary to open the cellphone and clean the contacts, you have to check the charger plug too and if not responding after this, the problem is in some element that acts in the charger interface of the phone
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
