It'll probably lean out the air/fuel mixture and over time, yes, it can hurt the motor!
With fuel injection, you'll need to either take it to the dealer so they can plug it in to their computers and reprogram the injection, or buy a "piggy-back" unit that plugs in, to "fool" the system to run richer.
Yes it can hurt the electrical system if you disconnect the battery while the engine is running. It can toast the diodes in the alternator and cook the computer along with other problems. You'll need to check the fuses and the engine computer.
Your printers' app is keeping your Imac from shutting down. You have to quit the printers' app first then shutdown. Some outside vendors' apps (as Lexmark - has a function that prevents you from shutting down computer in case you have stuff printing) You can change that in your Lexmark preferences. And no it won't hurt the IMac, it's just a hassle until you change the printers' preferences.
No your PC is not hurt. The problem is that you motherboard is having problems reconizing the charger. I recomend calling Dell Costomer Service and telling them you problem and have them replace the motherboard and or battery.
Flashing logo of company on monitor screen means your monitor has power but not receiving data. Have to find a way to fix data, may be data cable ( vga cable ) of booting of computer itself
Try few things not sure solve your problem or not but really doesnt hurt to try
First, It looks you have loose VGA cabling. Try removing VGA cable completely and connect again
Second, if above doesnt solve the problem, may be your VGA card has problem or your CPU is not booting up. Feel the breeze of fan on SMPS to see if it is working or not.
You are not hurting your truck at all... the engine computer adjusts to the lower octane... you may notice a slightly higher fuel consumption with the lower octane fuel but the money you save on lower octane fuel offsets the mileage.
Sir,
It depend what softwares they. like official company as Acrobat wont hurt any of your computer but it dows matter where you are downloading it from as many site are the source of Virus. Yes the local made software could hurt or may not. there is not gurannte but you can check the rating on it
no it won't hurt to drive it, but have the computer tested for trouble codes, u most likely have an electric sift solenoid in the trans that has failed.
