SOURCE: i have a frigidaire affinity washer and e21 appears on display. what does it mean
E21 is slow drain. this means there is something clogging the filter in the hose from the tub to the pump. 1. unplug unit. 2. remove bottom access panel on the front. 3 be ready for water to spill lots of towels you can throw them back in washer when this procedure is done, so don't worry, pack the towels around the hose that comes from the bottom of the tub to the the pump 4 remove the clamp holding the tub to the pump 5 gentle remove the hose this is where you may get wet 6 reach into the hose you will feel a filter (cup like with holes in it) work is out of the hose it will be tuff but it will come out 8 now you have it in your hand clean it out all good 9 put it back it must be there so don't think of leaving it out , you must push it all the way back down until it is set in the grove for the lip of the basket. 10 reassemble the unit
